Power FC Chart Mapping
Here is the Excel file I used to map my Fuel and ignition tables. I am sure some of you guys out there can get some use out of it. I recently had Mick from subzero Dyno my car. You can clearly see the fuel he took out of it at PFC load Value 15-16. The car was being retuned at 1.10bar. The Ignition points around 15-16 need to be trimmed at peak torque to reduce detenation. Did make 225kw tho. When the timing is retarded I think it will negate the extra boost and all I`ll end up with is a slight increase in mid range power only, probably actually loose some up top.
  • Replies 58
HKS Super Dragger Ex
HKS Dump Pipe
mesh removed from A/F meter (stock r33)
Apexi Air filter /partitioned off
Greddy 28c tube and fin front mount intercooler
Heat wrapped turbo to cat*
*cat in pipe
heat wrapped intake pipe
Power FC
HKS solid twin plate clutch
Cut out front bar
Oil air seperator
Bosch Motorsport fuel pump
Motul 5w40 oil
Nulon G70 with auto trans fluid in the gear box
1bar to 1.10bar boost
HKS EVC4
Pureone oil filter
Stupidly huge fuel filter
BPES7??? plugs 0.7mm
BP ultimate 98 Fuel 1bar- with octane booster for 1.1bar,also another 2degrees added with octane booster.
I`ll modify this post if I can think of any more
Thank's Boostd, that format looks so good I might load our numbers into it. Not much use comparing our RB20 or RB30 with an RB25, but interesting nonetheless.
Originally posted by Steve
225kw with stock turbo!  1.1bar with stock turbo!!!! you're a very brave man:)
Your right on the money Steve, I only get near those figures with a healthy dose of octane booster and I still get a minor ping. I`m taking it down AIR for the next street meet. Fingers crossed I can get through another 6 passes.
Thanks boostd useful info.
I actually leaned out the fuel map at idle to try and reduce exhaust fumes (I don't have a cat fitted). Hunts a bit now (I took the AFM screens out also), but less likely to gas myself whilst idling in a semi-closed garage.
I'll drop my maps in for the RB26 and post here also.
Anyone else got RB26 maps?
Its Greg from base. What do you reckon try loading your figures into my car. Where could I go wrong. Our cars have the same mods virtually. Mine has only had one tune for an hour on a 43degree day. So there is nothing to loose. I am planning a turbo upgrade in the near future so it will have a retune then.
hey greg, you can give it a go-might be an idea to compare the two and make sure there isn't a huge difference between maps. what works for me might make no pwr for you and blow ur engine.
Steve- is what ur after different to the file i already posted up top?
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
