Steve Posted June 5, 2003 Share Posted June 5, 2003 oops, my bad, didnt notice the raw data at the top...thanks:) Link to comment https://www.sau.com.au/forums/topic/16374-power-fc-chart-mapping/page/2/#findComment-364849 Share on other sites More sharing options...
skyzerr33 Posted June 6, 2003 Share Posted June 6, 2003 i'll do mine over the weekend so u can compare. i get the hunt at idle so will be getting them to try the extra fuel u have or something similar Link to comment https://www.sau.com.au/forums/topic/16374-power-fc-chart-mapping/page/2/#findComment-365323 Share on other sites More sharing options...
grepin Posted June 6, 2003 Share Posted June 6, 2003 Gday Matt Greg again. Have plugged in your ingnition/timing figures. They are a lot more agressive than mine. Would I need to match the Injection side as well? I cant quite dial in the same figures must be different PFC versions I know yours is older. So the higher the figure the more fuel correct? Lucky I have a dyno day at Tilbrooks tomorrow to test it. Mark or Mick might get a good laugh at my backyard tuning. Link to comment https://www.sau.com.au/forums/topic/16374-power-fc-chart-mapping/page/2/#findComment-366098 Share on other sites More sharing options...
skyzerr33 Posted June 10, 2003 Share Posted June 10, 2003 hey greg how did your car go? Link to comment https://www.sau.com.au/forums/topic/16374-power-fc-chart-mapping/page/2/#findComment-372956 Share on other sites More sharing options...
grepin Posted June 10, 2003 Share Posted June 10, 2003 Well I grabbed Boostd data and made comparisons to mine. His had a lot more timing up to 4 deg towards the later load points. I matched his however didint touch the fuel side. I have a Z32 airflow meter which is different and good A/F ratios. Anyway drove the car and didnt feel much different. Maybe the fuel needs to be revisited along with timing ajustments. Anyway went to a dyno day and resultently made no more power however changed the power curve at peak to drop off later. Next we dialed in and extra 3deg which can be done via a single function the HC and only lasts until the motor is turned off. I made an extra 9rwkw however with indications of detonation. So a further 2 deg could be feasable. Anyway got on the road with a mate watching the HC and tried 3deg on the road. Felt strong howerver was getting 40 knock so puched in more fuel and reduced the knock. Took heaps of boost out and tried 4 deg felt just as good and had no knock. I wish I new all this playability a week before at the drags as potentil to put more fuel or timing accompanied with octane booster and tested my times could have been interesting. However the fuel side is the key and needs to be done on a dyno. Link to comment https://www.sau.com.au/forums/topic/16374-power-fc-chart-mapping/page/2/#findComment-373428 Share on other sites More sharing options...
The Mafia Posted August 30, 2004 Share Posted August 30, 2004 Here is the Excel file I used to map my Fuel and ignition tables. I am sure some of you guys out there can get some use out of it. I recently had Mick from subzero Dyno my car. You can clearly see the fuel he took out of it at PFC load Value 15-16. The car was being retuned at 1.10bar. The Ignition points around 15-16 need to be trimmed at peak torque to reduce detenation. Did make 225kw tho. When the timing is retarded I think it will negate the extra boost and all I`ll end up with is a slight increase in mid range power only, probably actually loose some up top. sorry for bringing up a very old thread, but the link doesn't work.. can you email it to (email removed) ??? I would love to put these setting into my powerfc Link to comment https://www.sau.com.au/forums/topic/16374-power-fc-chart-mapping/page/2/#findComment-994540 Share on other sites More sharing options...
R33vit Posted August 30, 2004 Share Posted August 30, 2004 Matt me too plz Link to comment https://www.sau.com.au/forums/topic/16374-power-fc-chart-mapping/page/2/#findComment-994719 Share on other sites More sharing options...
R31 POWER Posted August 30, 2004 Share Posted August 30, 2004 E-mails sent guys. Link to comment https://www.sau.com.au/forums/topic/16374-power-fc-chart-mapping/page/2/#findComment-995010 Share on other sites More sharing options...
The Alchemist Posted August 30, 2004 Share Posted August 30, 2004 :bp: I'm working on a R32 GTR map with Datalogit at the moment ......its a lot of work but am making progress. I can post what I've done so far if you like as an excel 3d map? :jawa: Mike Link to comment https://www.sau.com.au/forums/topic/16374-power-fc-chart-mapping/page/2/#findComment-995085 Share on other sites More sharing options...
Revhead Posted August 30, 2004 Share Posted August 30, 2004 Me too, send it my way please Edit: Removed addy to stop email trawlers Link to comment https://www.sau.com.au/forums/topic/16374-power-fc-chart-mapping/page/2/#findComment-995099 Share on other sites More sharing options...
The Mafia Posted August 30, 2004 Share Posted August 30, 2004 :bp: I'm working on a R32 GTR map with Datalogit at the moment ......its a lot of work but am making progress. I can post what I've done so far if you like as an excel 3d map? :jawa: Mike I am sure that the GT-R owners with PFC's would LOVE that, do it dude. Its a world of knowledge sharing I say. If I could give anything back ,I would be more than happy to I have some questions for this mapping you have sent. Why are some values in red? Are they of some importance or need to be monitored? And if I enter the 2 top maps in, then thats exactly what you have? Those graphs are just plotted from your maps right? (Sorry for my ignorance, I am not very good at this sort of tuning. Seems like you have a bit of a nack! Link to comment https://www.sau.com.au/forums/topic/16374-power-fc-chart-mapping/page/2/#findComment-995214 Share on other sites More sharing options...
R33vit Posted August 30, 2004 Share Posted August 30, 2004 E-mails sent guys. thanX Link to comment https://www.sau.com.au/forums/topic/16374-power-fc-chart-mapping/page/2/#findComment-995296 Share on other sites More sharing options...
raddavey Posted August 30, 2004 Share Posted August 30, 2004 Would like to have a look aswell to compare ignition timing. email please to daveyra@westnet.com.au Link to comment https://www.sau.com.au/forums/topic/16374-power-fc-chart-mapping/page/2/#findComment-995333 Share on other sites More sharing options...
The Mafia Posted August 30, 2004 Share Posted August 30, 2004 has anyone else got some maps that they want to share with us, to compare, that may not be so aggressive? Just a little worried about blowing pistons to pieces... Link to comment https://www.sau.com.au/forums/topic/16374-power-fc-chart-mapping/page/2/#findComment-995402 Share on other sites More sharing options...
GTR-Ben Posted August 30, 2004 Share Posted August 30, 2004 Yes please!! ben@nismo.org GTR one would be nice. Any one got a RB30 one Link to comment https://www.sau.com.au/forums/topic/16374-power-fc-chart-mapping/page/2/#findComment-995417 Share on other sites More sharing options...
666DAN Posted August 30, 2004 Share Posted August 30, 2004 Can someone please send me any excel data they have too, a base map from an rb25de would be VERY much appreciated too to help me counteract the aggressive timing of the N/A computer! dt@austarnet.com.au Link to comment https://www.sau.com.au/forums/topic/16374-power-fc-chart-mapping/page/2/#findComment-995428 Share on other sites More sharing options...
aqik33 Posted August 31, 2004 Share Posted August 31, 2004 Can I please have the power FC zip file to. please, please, please. d.frost@bassett.com.au Link to comment https://www.sau.com.au/forums/topic/16374-power-fc-chart-mapping/page/2/#findComment-995642 Share on other sites More sharing options...
cameron Posted August 31, 2004 Share Posted August 31, 2004 If anyone has a gtr with hks,trust internal wastegated turbo, bigger injectors, fuel pump, etc. Would it be possible to post your ign & inj maps ? Link to comment https://www.sau.com.au/forums/topic/16374-power-fc-chart-mapping/page/2/#findComment-995654 Share on other sites More sharing options...
The Mafia Posted August 31, 2004 Share Posted August 31, 2004 here, I hope Boostd doesn't mind, but I have got the Excell Spreadsheet here for download as a zip http://members.iinet.net.au/~sennan/fcmap.zip (right click, save target as) Link to comment https://www.sau.com.au/forums/topic/16374-power-fc-chart-mapping/page/2/#findComment-995809 Share on other sites More sharing options...
666DAN Posted August 31, 2004 Share Posted August 31, 2004 linkage is brokage And if anyone else has an RB25DE map....... Link to comment https://www.sau.com.au/forums/topic/16374-power-fc-chart-mapping/page/2/#findComment-995818 Share on other sites More sharing options...
