  • Replies 58
HKS Super Dragger Ex
HKS Dump Pipe
mesh removed from A/F meter (stock r33)
Apexi Air filter /partitioned off
Greddy 28c tube and fin front mount intercooler
Heat wrapped turbo to cat*
*cat in pipe
heat wrapped intake pipe
Power FC
HKS solid twin plate clutch
Cut out front bar
Oil air seperator
Bosch Motorsport fuel pump
Motul 5w40 oil
Nulon G70 with auto trans fluid in the gear box
1bar to 1.10bar boost
HKS EVC4
Pureone oil filter
Stupidly huge fuel filter
BPES7??? plugs 0.7mm
BP ultimate 98 Fuel 1bar- with octane booster for 1.1bar,also another 2degrees added with octane booster.
I`ll modify this post if I can think of any more
next time you want a tune up a freind has datalogit for r33 gtst... he made 280rwhp with stock turbos at 14psi....
i can arrange my tuner to tune it for you with his software in brisbane at a good price....
cheers...mark
  • 2 months later...
man took me ages to find this thread again. im sure everyones thats in the powerfc from the group buy will be looking for this thread also.
just a question.
would the fuel map work on any car with similar mods? if boosted or not boosted.
can anyone post anymore rb25det maps and list your mods.
thanks..........
My car had stock inkectors and fuel pressure, so the map would run your car. I have to stress that at high boost it detonated quite badly without 98 octane fuel. Every car is different ! But it may get you into the ball park before the final tune saving some time and therefore dollars. My base timing may have been retarded making the advance on the map look huge....there are soo many variables even on similar engines.
I would like to see the GTR map too.
I will be getting my car tuned at Gavin Woods in feb with following mods, so hopefully i will be able to post maps then:
GTR 33
Tomei 260/260 poncams, GT-SS Turbos, Z32 AFMs, HKS Cam Gears, TomeiFuel pump, TrustI/C,700cc SARD inj, 3inch exhuast, blitz id3 BC
  • 2 months later...
here, I hope Boostd doesn't mind, but I have got the Excell Spreadsheet here for download as a zip
http://members.iinet.net.au/~sennan/fcmap.zip
(right click, save target as)
ha just having a look at the fuel map ,seems a did messy to me
we spent a lot more time cleaning up off the normal power run path and trying to keep smooth transistion between different sectors
only in my opinion tho
  • 1 year later...
what tune are u after? i have a few
hi there..
i need a tune for my power fc i use T04Z turbine, greddy inlet plenum, 1000cc injectors.
thanks.. really appreciate it if u could email me on tomei_gtst@hotmail.com for the charts. thanks.
once again thanks.
hi there..
once again thanks.
so goto a tuner and get a real tune then
hard to get a tuner here mate in my country. have to wait few months.. thanks.. can u email me just a light tune mate maps.. i think the ignition maps are too advanced.. thanks.. if u could email me on tomei_gtst@hotmail.com. the tuner will come june 2007. and thats a lone way to go.. i really appreciate if u could send me one.
thanks.
im not sure what you are asking?
if the timing is too advance, back out timing using the temporary IGN adjust or edit it on the maps. this is covered in the PFC Faq in my signature.
there is no need to load someone else's maps, in fact its probably a bad idea
  • 1 month later...
cheers...mark
Any chance of getting yours friends contact details as I'm fitting a PFC and FC boost controller and need a good tuner thanks in advance :D
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
