im selling my 32 4door B&N kit
its been fitted by a crash shop, all the skirts front and rear all line up wickedly..
still in the white gellcoat
no cracks or anything,
PRICE
$550
located in adelaide
CONTACT DETAILS
Sam
mob# 0411684008
email - [email protected]
or PM me
OTHER DETAILS
kit was orginally from VivaGarage which sell for $750
this way you save 200bucks and dont have to worry about the kit not lining up or fitting :yes:
rear bar has some carbon (black marks) from the zorst
PICS
32 4door B&N kit pics
https://www.sau.com.au/forums/topic/163774-r32-4-door-bn-kit/
  • 4 weeks later...
  • 4 weeks later...
  • 3 months later...
  • 1 month later...
