Item: Pioneer in dash TV/DVD/MP3
Website: http://www.pioneer.com.au/products/c...DVD/index.html
http://www.pioneer.com.au/products/c...TVP/index.html
Item Condition: Great had it im my car old n14 for around 6 months
Reason for selling: Dont use it anymore and need cash
Price and price conditions: $1200ono+ postage if required
Extra Info: Includes the Tv tuner worth $999 alone making the total value well over 3k all you need is the tv areals 2 plug in and your set.
Pictures:
Edited by RUF32R
The specs are;
IN-DASH 6.5" TOUCH PANEL
DVD/VCD/CD SCREEN
· Dual Zone Facility
· Hideaway Module
· Touch Screen Operation
· MOSFET 50 watts x 4 High Power
· PAL and NTSC compatible
PRODUCT DESCRIPTION
In-dash Motorised 16.5cm Screen with Integrated DVD Player, AM/FM Tuner and High Power Output, Dual Motor Drive for superior operation and rigidity, Detachable Face Panel with Theft-deterrent LED, IR Remote Control supplied, Dual Zone Facility (F=Tuner/MCD, R-DVD), 10-character Sub Display when screen closed, Hideaway Module (1.5m cable): 150 x 28 x 100mm
LCD MONITOR
Touch Screen operation, Anti-reflective and Fingerprint resistant screen coating, Rear View Camera Input (camera not supplied), Auto Switching to Rear View when reverse gear selected, 5 Viewing Modes (Widescreen, 3:4, etc.), Adjustable Screen Position with Memory, Set Back screen, 2-position selectable, TFT (Thin Film Transistor) Display, PAL and NTSC compatible, On-screen Setting Menu, OSD, Auto Dimmer Control
SUPERTUNER FEATURES
Supertuner IIID with Digital Processing, Provision for upgrade to DAB, Selectable Local/DX/Local Seek, 9kHz/10kHz switching
PLAYER FEATURES
DVD for Region 4 and "Open" Discs, Compatible with CD, CD-R, CD-RW, VCD, DVD, DVD-R, DVD-RW, Suitable for Double-sided and Dual-layer Discs, Search by Title, Chapter, Time, Direct Playback for 8cm Discs, Built-in MPEG 2/1 Decoder, MP3 Playback with ID3 Tag
SYSTEM CONNECTION
Optical Output for Dolby Digital and dts 5.1 audio, PCM Linear Stereo Audio Output, RCA Input (L+R+Video), RCA Video Input for Rear View Camera, RCA Output for Rear Screen (L=R=Video), AV Bus Input for GEX-P6450TVP TV Tuner, Pioneer P-Bus Input, Multiplay CD Control
AUDIO FEATURES
MOSFET 50 Watts x 4 High Power, Rotary Volume Control, EEQ+ (Easy Equaliser), EQ-EX (Augments EEQ+), Dual + Sub 4-Volt RCA Preout, 2-way Crossover: 50/80/125Hz, Direct Subwoofer Drive, SFEQ (Sound Focus Equaliser), Digital Listening Position Selector (LPS), SLA (Source Level
Seeing as ur in need of cash, PM me with the $ you want for the dvd player without the tv unit.
I can pay today, depending on how much you want.
Please include postage to Mildura, Vic with your price (I'm not one for haggling, so I'll either take it or won't).
Thanks.
Thanks.
PM sent
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
