u sya he has it in his race car and its easy to teak for him at the track!! what about street use? would it be the same?
Yeh well as far as i'm aware it is very tunable, But in saying that we pulled out every single wire in the car while building it! And from what i can remember its a computer that needs to be fully re wired! But dude like i said work out which workshop you want to take your car too and choose a computer that they can tune! otherwise you'll be chasing your tail! and paying for it!
https://www.sau.com.au/forums/topic/163810-pfc/page/3/#findComment-3043984
  • Replies 48
I gotta a mate with a microtec and they are ok but fuel hungry, when deluxe says wolf he thinks rotor, when i think microtec i think rotor. there pretty good but very hard to fine tune as they just dont have the load points and very fuel hungry.
https://www.sau.com.au/forums/topic/163810-pfc/page/3/#findComment-3045157
They can use excess fuel if tuned in normal mode, as most are, but if tuned in Matrix mode they can be fine tuned much much better, In matrix mode there is a load map for every 500rpm, wher in Normal mode there is only 1 load map and a cruise map.
https://www.sau.com.au/forums/topic/163810-pfc/page/3/#findComment-3045294
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
    • Should have asked what is the car?
    • I've had two super conflicting experiences with blue slips. My 30 year old E39 waltzed through with no issues but my brother in law was knocked back on 12 y/o 3 series due to wiper blades and some cracking in a control arm bush.  What kind of coil overs? Do you want to keep them after?  If it was me I'd get some dirt cheap shocks and springs from eBay or scumtree. Not ideal but will get you over the line and might even be less than $1k.
