hey mate glad to see you come to vic the place to be 'defected' (old joke atm)
any with the speed limits be very carefule as there are fixed cameras every and cops to.
as for speed limits in the areas youve said they change as with evey thing. so look out for the sings, thier white with a red circle with the speed limit in black on the in side of the circle.
if you dont know the speed limit of the road sit on 50km/h or a bit slower then what every body else is doing.
hope you fun when you come down too bad you an't here for the serneto cruise on the 21st.
have a look in the events section for all the info on it if you wish to come.
chears brentt
[quote name='andz69' date='9 Apr 2007, 07:50 PM' post"
btw, whats the speed limit in the city? 40k? 50k?
C u around
40, 50 60 70 and 80 and that could be on 1 street..
Just have to keep watching the signs mate ...
Im in the city tomorrow if i spot ya will give ya a wave ..
not sure i'd be advertising where my R34 GTR would be located for a given period, i know it's not exact... but yeah, maybe that's just me...
main thing is to keep an eye out for school zones, during school times, when the speed drops to 40. Can be a 70/80 speed zone, but will drop to 40 if it's the right time.
If you are stuck for something to do on the Tuesday night, come along to the monthly meeting which is in South Melbourne, about 5 mins from the CBD.
Link to thread:
http://www.skylinesaustralia.com/forums/in...howtopic=164024
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
