well wing or no wing, the skyline looks good both way depends on your taste and how you want your skyline to look like. right now i decided to have a wing ^^ makes it look more sporty and faster, with out wing i rkn more classy and mean as u siad
Is it $150.00 painted and installed? If so, I'll be seeing you this weekend!! I like how it emphasis the rear more... nice
Are you serious mate? Good luck getting anything even painted for less than that price let alone fitted AND supplied.
I like the drift/stealth wing follows the lines of the car nicely and makes it look nice and sleek.
At a guess, around $300.
Thats weird, for a genuine GTR wing only $300? You sell them for $350 on your website and their fiberglass not pastic... no led for the brake light either...
I know i'd never sell mine for $300 :nyaanyaa:
Your wing is a 2nd hand, PSI's new.. that's the difference.
It's a normal GTR wing? For Real??
I thought it looked a little bigger than a normal GTR wing. :)
Its an extension for the normal GTR wing.
The GTR wing we sell is very competitive compared to others around. I personally cannot see why a wing would be worth more than $350, but that is up to the person buying it.
Yes we could, however that wing uses the factory GTR wing and has a list price of $1700.
AHhhhh which GTR wing does that come from and its geniun? plus aint that too much lol or are you pulling all of our legs on that price lolz
I tend to think GTR wing's a tad little small.
I like Gracer's wing though....
PSI Parts, so if I wanted a Gracer wing by it self? Would you be able to supply?
Nice GT-R, nice kit etc... but with this is car... more show and less go... go over humps.... potholes etc will be a pain in the neck....
Here's my ride anyways... please tell me if you think it looks better with or without the wing?
http://www.skylinesaustralia.com/forums/in...howtopic=164999
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
    • For most rotisseries, as Duncan has mentioned, you really don't want a full car on it, you want a stripped shell. And imagine how many more weeks THAT is going to add to working on the car...
