Well I got on there & sorted 'em out. Of course, I am one of them as well, but I need a tow car & the carbon fibre diffuser under the R34 gets in the way of the towbar!!!
We will have to watch out when they all start throwing big turbos on them though - seems all the dyno comp guys are running turbo
injected V8s. At least when it gets twisty we'll be gone.
Guest Yoda
My post:
"What can I say. I recently sold my ClubSport to buy a Skyline! The performance is unbeatable. It was a week of driving before I could get out of the car without shaking from adrenaline. Its not just a straight-line machine either. The cornering performance just has to be experienced to be believed. The HICAS (electronic 4 wheel steer) will change your life. A '93 Skyline has more features than a '98 clubsport! (climate control, electronics, lock system, etc etc etc). I'm totally sold on the skylines. You look at these cars, read the specs and think 'wow', but honestly, that does them no justice. You just can't imagine what they are like. Do yourself a favour, find a good Skyline driver, and ask for a ride. They aren't called Godzilla for nothing..."
Hardly does it justice, but how do you describe to a Holden owner what a Skyline is like? Its like trying to describe sex to a virgin...
Originally posted by JimX
I think it's funny in that thread there is someone saying "2 many R33's round these days" in a Commodore forum!
hahahahahahahahahahahhaaaa
It would be good for US if skylines were so common in a way.. we would get heaps of cheap parts etc :P and cheap insurance!!!
ahhh well its nice to dream
Guilt-Toy, I don't care that R33's are common either, but I do get annoyed to hear the "R33's are everywhere" thing, when they are still far far short of Commodores and Camries and Falcons etc. No one ever comments on that, not even me because I really don't give a toss :P
I thought they were very open in there comments and most of them did not cut imports down like they normally do. I loved my SS when I had it but my skylines is a much nicr and faster car to drive but I'm sorry, you just cant beat that V8 roar. (except a GTR with open external watergates)
Good on you guys.
Guest Yoda
they have been quite good on there actually. i'm keeping an eye on the post. they know they cant match a skyline for performance. they complain about 'riced' cars, with wings etc. mods to make a slow car look better, but what about all the dunny lids on commodore bonnets!?! and the stupid wings (like hrt bathurst size wings), and other half assed mods (under chassis lights, where only one side works). they are way worse than 'riced' jap cars. its just so common everyone's used to it
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
