For those that know how bad the factory interior paint is on the R34's (seems to dissolve in the Aussie heat)
I've found a low-semi gloss alternative that seems pretty good, Powerplus PJ9184 "SNB 150 Desert Rose Metallic"
Just soak/scrub the original paint off with metho, takes no time at all, prime and hit with this stuff and in comes out looking pretty swish again.
  • Like 1
lol....that shift knob took some pure luck to get! I thank a certain member of SAU for taking me up on my offer...I literally stumbled on it in the for sale section....and yes it is awesome!
Tamiya (model) spray paint I tells ya....no priming necessary, great range of colours and they are meant for plastic
http://www.skylinesaustralia.com/forums/in...st&id=91076
http://www.skylinesaustralia.com/forums/in...st&id=91075
Mate good work, You funny enough picked the same colour as I did .. For your infomation it is very similar to the GTR paint work .. except it extends the entire length of the dash.
In regards to wiping off with metho .. big no no, that particular paint is very sticky when you apply metho, which means bumpy surface for new coat...
To remove spray on a plastic primer or spray paint, let top dry .. hit it and sand it back bare with a 600+ grit paper. it works best because it removes the paint in chunks and its quite easy..
Using metho is just too hard..
Now dont forget to use a plastic primer undercoat to make it stick hard!
About 4 layers of clear will ensure a long lasting protection system from scratches..
and make sure you mask that damn AC control .. I dodged mine need to sand it back im pissed every time I look at her.
Enjoy your job it well done, hope you remembered to do the window/mirror controls too because they have the same shit paint!
You've got to soak it, I mean literally dice it in metho otherwise yes it will be sticky. Sit all the parts in a shallow tray, submerge where possible and the paint falls off with little to no help...get one of those kitchen pads with the green on one side. If you're not up to your elbows in metho, you're not doing it right :dry: You'll be back to virgin black plastic in no time.
With the A/C you need to pop the plastic screen out *carefully* when you're done glue it back in as you would have damaged some clips for sure. Same for the red and blue bit, cut of the melted plastic pins that hold it in, the glue them in when done. There's nothing easier than just painting the whole thing without worrying about masked edges.
Good one you gave me insparation to do do mine. But instead of metho i used gp thinners and a white scouring pad. The hardest part was putting it all back together. I had some left over paint so mines proton gti silver. ha
hey man where are u located, are u able to help me do mine like that it looks awesome
So have you painted the gauge section, air con etc as well?
The picture is a bit iffy for my eyes because the flash might have just made it look that way..
Looks good though :blink: same for Dan's too.
Yeah you have to be patient that's all, remove the A/C plastics carefully and you'll get a professional finish.
Yeah my one is GTR style (even bought the brushed aluminium dash insert for the gauges) the gear surround is sonic silver (Nissan) and the A/C and triple gauges are Desert Rose metallic.
hey mate looks good, but what are those 3 gauges in the single din console, what brand are they? what were they worth and what are they measuring?
i did my r34 door window control plastic and centre console as well... gloss black.... the factory finish is pretty poor and scratches easy... only part i havent done is the pods where the 3 factory guages are.... how do you take that off without wrecking it??????
    • Ha ha ha! I know those feels mate I've finally got the garage cleared enough that next weekend I'll do some actual work on my car (hopefully). Unfortunately garage isn't usable after 10am at the moment That said, I've done a lot of work this weekend on helping finalise a friend's Production Race car. Full started Christmas Eve. We're down to about 8 tasks on the list, including "get a wheel alignment". Sometimes it's just easier working on someone else's car or project than our own stuff 馃槢
    • Ha ha, ended up going it alone.  I just sent it (in a very nervous fashion).  Once I'd released the locks and it didn't automatically start spinning out of control i felt a bit more confident.   It made some loud sounds (cracking and creaking noises) when I first spun it which got the heart rate going again!  I couldn't bring myself to leave it tipped on the side.  I feel a bit more comfortable having back right side up while it sits there. I'd get angry with your last point but you're 100% correct! 馃槄 Even yesterday I managed to distract myself at numerous times to make a bracket to fit an LED flood light off the back of the house and fix my sons pushbike.  There were other little taks nibbling at my brain for the rest of the day too...
    • Probably one of the more nerve wracking experiences of my entire life! 馃槀馃槀 The balance (centre of gravity) is out still but in a direction that gives me comfort!   It's quite bottom heavy still meaning it takes a bit of muscle to rotate it.  The plus side of that is that it wants to to go back to upright.  Better that than wanting to go all stranded turtle on me!
    • hmmm that's not ideal. This is a pretty new engine right, will be interesting if your engine guy has any theories about causes
    • A universal ball joint removal c press kit is better money spent and will work for the Hicas ball joints.  Here's a 45$ CAD Example. ATPEAM Heavy Duty Ball Joint Press Kit with 4WD Adapters | Professional 4 in 1 Ball Joint Press Removal and Installation Tool for Cars and Trucks | Universal Ball Joint Tool with Storage Case, Ball Joint & Tie Rod Tools - Amazon Canada
