i have to lol at how many people have used powerplus tungsten, i spose it really is just that nice of a color :D
I was first !! I think ... went black, silver and then tungsten. Def a nice colour and not too blingy, goes with any interior.
I've read through this forum quite a few times now and when it comes to the red and blue lines on the air-con I'm a bit confused http://www.skylinesaustralia.com/forums/st...fault/blink.gif From what I've read you melt the tabs holding the knob to remove it but from what I can see the lines aren't part of the knob but more a part of the whole air con panel? From the pics people have posted they have painted the raised part around the lines too? do you just mask the lines? Are my eye's deceiving me? Help.........
when you pop of the fascia around the aircon you will notice that the red and blue sections, and also the plastic panel covering the display all have several small round dots of what looks like melted plastic rather than screws or clips (the plastic panel does 2 small clips, one either end as well as the melted dots)
you have 2 options, one is to melt those dots so that you can pull out the plastic panel and the red and blue bits, or you can do what i did, and use a sharp knife (stanley/stencil knife) to cleanly slice off the little plastic melted pieces which will then allow the plastic panel and red and blue pieces to simply pull out.
when you want to put it all back together, simply slide it back into place and use a tiny amount of super glue or something similar and just drip it onto the holes that the red and blue and plastic panels are held in from, dry in a few minutes and presto! you retained the colored parts of your aircon
Ahhhh now I get it :P
Yours looks great BTW! Did you use metho then plastic primer then paint?
Thanks.
cheers bud, and yeah i just used the metho first, came off pretty easy, dried it with a rag and waited 10mins or so, hit it with a few coats of plastic primer, and then the paint with however many coats it took to get it nice and even.
that said, i need to pull out the gear stick surround and ac vents again and re-paint them cos luckily you can only see it on certain angles but i didnt get a very even coat :)
Ok here is mine, i wasnt going to post it as so many people have used the tungsten but anyway decided to post it up.
sorry not the greatest quality, took it using iphone.
cheers,
David.
cheers,
David.
put your gear boot back on properly david :sick:
cheers,
David.
lol damn you, i want your gauges!, both the speedo and triple gauge cluster!!!!
haha good pick up on my laziness,i also forgot to change the stereo colors to red to mAtch the guages.ill get another pic up all fixed soon hahaha, its all coming out in a few weeks to put the MFD in so ill fix it then ..........
stereo colours or ac colours?
were you going to take apart your head unit to change the colours? :sick:
no this Alpine Unit is the CDA - 9887 model the colors can change by the turn of the dial to match accessorise ( reds / Blues / Greens / oranges and mixed as well. look it up on youtube theres a demo. I think these units are now selling for $599 at JB - Hi Fi originally over $700
  • 3 weeks later...
does the astray lid need to be removed? or just dip the whole thing face down into metho?
Yeah just throw it in and give it a scrub. Just mask it up neatly when spraying so you only do the cover.
Hey David are you gonna be using the existing tripleguage wiring loom for MFD or a new one? If you're not gonna need the existing loom would you consider selling it? I converted my R34 from the pop-up screen to triple guages but I don't have the correct wiring loom for the triple guages..
sorry for jacking the thread, i'll keep you posted Denis,hopefully ill have the new GTR MFD wiring loom soon from Nissan Japan.ill let you know.
cheers,
David.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
