Looks great NZMO. In fact all of the ppl that've done this to their consoles have done a good job.
I am right in the middle of doing my centre console and window controls in Powerplus Metallic Cyan Blue...or whatever it's called. Looks great to me...Should have photos of the whole thing when I get it all back together tomorrow.
I tell you what though! It is a mission to get the CD, Aircon and Tape Deck facia pieces off! So many screws on the CD player it's nuts, but I made sure to put all the screws into the facia backing so I don't lose any. Now I know how to do this I think I'll write a guide on it so other poeple can do it. unless this has been done before.
OK, finished the CD, Aircon and Tape Deck Facia Pieces. I also re-did the Vents as that was a shitty job and I hated myself for doing it so quickly just so I could get it into the car again.
So, here's a pic of the console and one of the drivers window control surround.
Oh, and when I put the Aircon Unit back in, and hooked all the wires for everything back up, I noticed that the buttons on the aircon unit for Fan Speed (up and down), Mode, A/C, Auto, Off and Direct/Re-circulate didn't come on when I turned the headlights on. I tried tapping on the panel, and all the lights bar the ones behind the Direct/Recirulate buttons are now working, but this has never happened before. I checked the lights last night, but I think I may be in need of replacing the LEDs that are in the back of the A/C control unit.
Edited by tmg
Hi all,
I've decided to go with the Tungsten silver too but was unable to see it a Supercheap? They had about 10-15 types of silver but no tungsten? Could someone please let me know the code so I can either order it in or see if they have changed the name :P
Thanks.
  • 4 months later...
its not a solid black underneath, its sort of a sparkly gray color, so you will need to spray it black and then add gloss if you want the shine, but i think a matte black would look heaps better, someone in this thread has done it gloss black i believe
i still havnt done mine yet when i take the astray and screws out and undo the gear shift i cant seem to get it off i dont know how
can someone please inform me step by step how to get it off from the
gear shift then to take out tape deck then cd then ac then the pop up screen which comes with the car
thanks..
Im pretty sure i wrote up step by step how to do this in this thread, as have a few other people, go back a few pages and have a look, if its not there, do a search for R34 interior or something similar, because i know i have explained it in detail at least 3 times in different threads.
thanks..
ok so i know its been covered but, i have finally removed all the parts of the interior
what is the absolute best way to get this crappy paint off and what is a good paint to re paint with and how many coates recommended ?
thanks.
thanks.
lol yeah, it has been covered in this thread, not trying to sound rude but its only a few pages back.
Metho and a steel wool scourer will get it all off pretty easy, wash it off afterwards, dry it, then use plastic primer from Super cheap one or 2 light coats, then a paint also from super cheap, cant remember the brand, its been mentioned a few times throughout the thread. as many coats of paint as you feel necessary to get a nice even cover. (i did about 3 i think)
nah your not being rude i understand your fustration lol
i just like to be told directly
i am just gonna fill up the sink with metho and drop it in then take it out and scrub and do that acouple of time hahahaha
wish me luck hopefully done by monday so i can post up some pics
thanks
  • 3 months later...
  • 1 month later...
Thank-you to everyone for the inspiration and insight on the know-how's. I was getting very annoyed at the sticky, unprofessional looking center piece and decided to do something about it :happy: I ended up using Power-plus PJ9184 as advised by the OP :cool: What I didn't use is clear coat :)
Edited by theponyremark
  • 4 months later...
  • 3 months later...
  666DAN said:
For those that know how bad the factory interior paint is on the R34's (seems to dissolve in the Aussie heat)
I've found a low-semi gloss alternative that seems pretty good, Powerplus PJ9184 "SNB 150 Desert Rose Metallic"
Just soak/scrub the original paint off with metho, takes no time at all, prime and hit with this stuff and in comes out looking pretty swish again.
Hey mate,
That gear shifter is wicked! Where do I get one!?
Lovin the look of the whole console to tell ya the truth, mine has def seen better days so im taking you advise.
Cheers!
  • 3 weeks later...
  • 2 months later...
:domokun: i have done my dash the exact same ! mica blue ? and in the middle of doing my window controll grate minds think alike grate job mate ill add my pics up tuesday wen i get my camera back :)
  • 4 weeks later...
thanks to this thread it took me all of 15mins to pull out all the plastic
also the door controls just pop out ...well mine did... the passenger side is abit tougher but still just poped out (with force)
was all too easy ....only broke one small clip on back of ac strip which is not seen anyways
was a little gun hoe and accidentally took the actual triple cluster itself out of its casing...whooops :unsure:
im going to do the little door handle /coinholder? bit aswell so it all matches
off to supercheap for the paint etc this morning they better have the right color :sick:
thanks to all that contributed info on the thread as it made it alot easier and quicker
CHEERS SAU
:D
  • 1 month later...
  On 30/03/2009 at 2:28 AM, RusH_ said:
Ok well i did mine a few weekends back now, but figured i should post up, so here goes
post-40562-1238379919_thumb.jpg post-40562-1238379950_thumb.jpg post-40562-1238379987_thumb.jpg
Do you know who does that or where can do I that here in Perth ?
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
