Shitty Series 1 R34 Interior Plastic Paint
Old thread I know, I don't like the texture of the trim in my GTT, so I can across this thread. I wanted a nice smooth wipeable finish. Anyone tried these yet from what Ive seen the texture is still the same?
Not shiny smoothe but before I redid mine in real carbon I used hi temp cast iron engine paint
Looks like a titanium colour matte finish think it was motormate or vht
You can get titanium silver krylon but my intake plenum is painted that colour and it would be crazy sparkles on the dash , way to blinding
the cast iron paint can be clear coated if you want some gloss and smoother ? a damp rag cleans it fine dabbing it ?
Carbon for the win lol
Im trying to avoid carbon or anything aftermarket. I don't mind the OEM color but the texture make it difficult to clean dust or dirt. But I started taking if off with simple green and its the paint that creates the texture that I don't want so the problem is probably resolved. This is my 1st interior DIY already jacked up one piece the rest is coming along. Im going to need some filler though.
Ok what is "metho" I'm an American living in Japan.
I used paint thinner on one piece which cracked it and simple green on the rest. The simple green and 400 grit and it came off pretty easy.
Sprayed it flat black, might spray it again if it doesn't look good installed.
Mentholated spirits is metho ,( I'm from usa ) like alcohol based cleaner thinner
Simple green is rare find down under ( bunnings sells it now for australian who want a good product )
Sand it
Wax and grease remover it
Plastic pore primer paint( for dashes and plastic bumpers )
Then spray it so it wont fall off
The cast iron paint is very close to factory gtt series 2 gauge colors which look way better the that crap in series 1 cars had( and is heat proof bonus) cars can exceed 80c in summer !!
Abs plastic ( dash parts)can and will melt with some paint thinner type products , wax and grease remover is safe , must use it or paint will fish eye !! dash protector overspray exists and oily skin fingerprints ruin paint jobs
Matte paint requires special cleaning care or it gets shiny /spotty looking
Edited by Carbon 34
Thanks
Everything is done and back together with the help on my friend who does custom car A/V.
Every thing you mention plus some is exactly what we did to fix the triple gauge cluster.
The paint does look better but Im not sure how easy it will be to clean than before cause the texture is not a what I was hoping for.
Prior to painting it was perfect, they sprayed something on it they referred to as "surface" after which it look like it was fresh from the factory but smooth. If he doesn't work out I'll just strip it again and the the paint shop sort it out since it was rather cheap just for the spray.
Thanks
If you got more then a satin texture its not the right paint ? And you can always satin or gloss clear it to get rid of the physical texture but retain the background metal look ? just a thought ?
how do you get the trim off ?
Safe way remove door card , flip over and undo the screw , use care the nose breaks off easy, drop switches off by the silver screws and black one with clip
Other doors pop out but better to do it with cards off so you dont break them
I personally like the stock look of the paint. It does melt off and become sticky in the sun over time if left out for extensive periods, but my way of fixing it is just put all the parts, put it in a freezer and freeze it for a good 30 minutes, take it out and let it sit to room temp and voila! Good as new.
how often would you need to do that but, I'd imagine it would only be a temporary fix?
as opposed to taking it all out at once & painting so it's fixed for good. you could replicate the look of the stock paint with a flat grey
I've only done it once in the past 6 months. It hasn't wanted to melt of yet after sitting in the sun for a bit. Feels like new, even if I try to scratch it off, its not as easy as it would if it was melting off.
  • 5 months later...
sorry for the crappy quality, bad lighting in the garage!
Had a bit of trouble getting the AC control surround off, mainly the clips around the temp control knob. Just snapped it open and glue'd the clips back after lol.
lol thanks,
It's a shift extender with a solid short shifter base. The knob i got a while ago separately.
makes it that much more fun and easier to shift :D
Hey mate, did you use powerplus tungsten? If not which colour is that you have on there? Looks good. Has any of it peeled or cracked without a clear coat also?
Cheers
Cheers
Nah i couldn't find the tungsten, they had none in stock. I just chose something that looked similar, it was called Sandstorm (Holden sandstorm is the same thing also). No cracks or anything, and no clear either.
Sweet as thanks for the reply. I brought Tungsten today (last one on shelf!) Have used thinners to clean back the surface and gave it a light sand. Will prime it tomorrow, only doing ash tray and gear console surround at this stage, when I take my head unit out and replace it will do that part then. Good to know its all sweet without clear coat, looks great
    • As far as I know, Infiniti stopped importing vehicles before 2020, even though they were still selling their stock for at least a year or 2 after that, they were older build years, therefore, you can import a 2020 400R, because you couldn't buy an AuDM 2020 built Q50 RS. As for insurance, you might need to go through one of the enthusiast insurance companies, they tend to insure a lot more grey import models than the mainstream insurers as Duncan mentioned.
    • loved seeing the zenvo on the a1 just after the hatfield tunnel i was the guy in the white van trying to egg you on it sounded awesome and those exhausts glowing red inside insane cheers for the thumbs up tim and tom.
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
