So I painted mine today in the Tungsten, looks awesome. Will post up some photos tomorrow when I put it all back togeather. Will definitely be doing the both window with surrounds in the near future. Just hope the paint doesn't scrape off.....
Here's my pictures, crappy iPhone quality doesn't do the colour any justice! Tungsten gold is without a doubt the best colour. In sunlight its stunning 100% recommend it. Now, bit of info regarding the passenger window switch, not only do you have to take the door panel off, you then have to take apart several clips holding the switch onto the door panel! These aren't fun, you need 2x flat heads to bend clips in and push the switch out. Drivers side one just pops out, and centre console was simple enough. I ordered that shift knob from nissan to match the colours :)
Apologies for the wonky photos :angry:
Edited by neopowered34
if you prep it properly then there should be no issues....i personally dont use the plastic paint you get and use enamel. Can get any colour you want then but its all in the prep! i then throw a clear over the top
Yeah I considered clearing my 1k acrylic with no clear. I sanded it, 3 coats of good primer and 3-4 coats of my colour and its turned out great. So far no scratching or peeling off, fingers crossed but I think it will be good. The plastic paint doesn't have a good variety, powerplus is the way to go :thumbsup:
My interior was so bad before.........scrubbed the black paint off to reveal another coat of silver underneath before i got to the plastic rofl.... guide worked awesome though..
Metho + wet sand + PowerPlus Plastic Primer + PowerPlus Nickel + 4 Clear Coats =
post-97358-0-08841900-1365938386_thumb.jpgpost-97358-0-47340300-1365938388_thumb.jpgpost-97358-0-51284300-1365938390_thumb.jpg
A/C vents, controller & Triple Gauge cluster all to be done in a different color...probably something a bit darker :D
Edited by fusion07
  • 3 months later...
My gear, radio surround and ashtray i painted in titanium silver, just for effect. But the rest of the plastics that has that "coating" like the power window controls and hvac unit i just metho'ed it off clean. Looks fine just as normal black plastic.
wow, you guys makes me wanna do it too, will show up some after pics
anyone knows how to do the leather look like the sides of that center console? i need to repaint that area as well, the paint got chipped easily in my car for some reason.
Assuming I'm talking about the same panel, the sides are actually vinyl not painted. Once they're scratched they're scratched (typically from pulling the head unit out and resting the metal brackets on there). I am actually considering 3M 1080 carbon wrapping them.
Yep, considering wrapping mine too. Looks gutted from my head unit brackets lol.
ah yes you're correct it looks leather-ish vinyl, whats the way to restore this? carbonwrap is nice, other than that?
Other than that, not much else unfortunately (that I know of). Some people have had limited success using shoe polish I think but it only fills in the scratches, won't get rid of them. Carbon Wrap is relatively cheap and you wont feel like youve dirtied your car.
Of course you could do what I did and try and source a replacement panel :D but good luck finding one not scratched lol
  • 5 months later...
Did mine in the last few days.
Despite a few issues, I finally put it back together today.
Do you guys think it would look weird if I didn't follow up by painting the AC and vents?
Thanks!
That looks great. I think you can get away by not painting the top half.
Btw: how do you guys remove the passenger door window switch?
I actually carbon wrapped mine while being bored at home.
Cheers man!
Damn that carbon wrapping looks kewl.
Looks so damn intricate around the AC and vents.
How long did it take you?
Cheers man!
Thanks man. A proper heatgun helped A LOT in this case.
It took me a whole day and I have no experience with this stuff. The top gauge holder looks crap as the bends were really difficult to get right. Might go back to the painted look...
In case this helps anybody, I had no experience before taking to my interior with the 3M DiNoc, its amazing stuff to work with but can be a bit tricky until you get the hang of it. Buy a little extra to give yourself some to practice with...
What I worked out to be verry effective was to have a spay bottle handy filled with water (room temp). Have it set to just lightly mist when you squeeze the trigger. When moulding the material around the corners of the parts and its hot, slowly work it by alternating between heating and misting to rapid cool. As the material will try to contract as it cools slow.
...It worked nicely for me, it's been on for over 12 months. looks brannoo ;)
  • 1 month later...
Hey does that gear knob still block the screen when looking from the driver's seat?? The stock gear knob is so tall!
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
