I also did some work to the interior. Stock > Carbon Wrap > Painted plastics..
Before..
Now..
And a new addition..
Im still not happy with the colour. Was more after a millennium jade look. Also we seriously need a group buy for those side kick panels that get scratched so easily!
  • 3 weeks later...
yeah very true, ive done mine in a charcoal grey it looks nice and its a different to the other colors people choose. each to their own... i just personally think carbon fiber is way over used in the ricer scene, hence why i think it looks cheap
Good tip:
Sand the hell outta it before you start painting...
Another tip... When you think you've finished sanding.... Keep sanding!
My paint is all furry and chips easily from when I thought I'd done enough sanding :/
Fully submerge the pieces in methylated spirits, let them sit for at least half an hour, then scrub the paint off with the green and yellow kitchen sponge, and then start to sand, I didn't sand mine to a ridiculous extent, just a couple of times over and they turned out really nice. Then I hung them from wires and painted them. I waited about 30-45 minutes between coats and did about 5 coats. I ended up using the whole can. Honestly it's a really easy mod that just needs common sense to be exercised. The hardest part of the whole thing was taking the pieces off the car, and that wasn't even that difficult.
post-137945-14213681825366_thumb.jpgpost-137945-14213681983557_thumb.jpgpost-137945-14213682085816_thumb.jpgpost-137945-14213682466488_thumb.jpg
  • 1 month later...
Thanks man, I just used a matte black interior vinyl/plastic spray that I picked up from supercheap. I think it was around $20. As for primer I didn't use any. I wanted a matte/satin finish and the primer in my opinion usually makes it looks too glossy and a bit cheap.
Hope that helped :cheers:
Edit: the paint was DupliCour matte black from supercheap
Edited by seejs
  • 8 months later...
  • 8 years later...
On 6/2/2008 at 3:04 PM, Jack88 said:
Recently i did all the plastics for my mates 34,heres some pics for you guys that wanted to see what a black colour would look like.its called saturn black its also heat and chemical resistant. theres some befores and afters in there too.
That's dope, looks very oem.
Anyone do this recently? I put a bit of methylated spirits on a paper towel and my head unit surround discoloured lol, went from black to yellow. And I noticed (especially on my ashtray as it was filthy) the material on the outside, took so many paper towels to get rid of the crap on there (some black stuff, not sure what it is), does anyone know why the hell these plastics are so damn sticky, is it just shit paint as others have mentioned?
With the sanding what grit to use and what is the purpose of sanding, is it simply just for the paint to stick better? I was going to go with a 800-1000 grit sand paper. Also how to know if it's sanded enough? Some people sanded theirs and the paint still cracked.
The problem I've found is that these panels have a texture to them. So sanding them removes the texture, which means you'd have to re-sand it all, and re-texture it all in some uniform fashion.
I believe there's various kinds of plastic fillers that are probably well suited for this, but I only ever noted it in the "Doable but pretty damn hard basket".
Plus, my scratches are on the passenger side :p
  • Like 1
  • Haha 1
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
