  • Replies 57
i wish they wouldn't allow drift anywhere. It's running the surface at most tracks. Making it way to bumpy.
most tracks hey? :P
as far as i know we only have 1 proper track here (ie mallala) and a half cast track (AIR). and most of the surface is f**ked there anyway.
where are they meant to go then?
Did you have any strut braces or anything???
nope, not a damn thing. i dont care if ppl tell me it was wrong, i just wanted to give it a go. the car is fine at home atm, still in top shape after i inspected it when I got home, only thing screwed up was my rubber, melting off the rim pretty much.
Edited by Pauly33GTS-t
If Paully doesn't buy the Bilstein coilovers I am selling REdgtst you should come check them out - a bargain at $600, and they are pretty hard - perfect for drifting!
I suggest you buy them REdgtst, I need to sort out my economy by getting an ECU now so I wont be spending any money on my car on suspension and handling until i sort that out. pretty clean ones as far as I can tell and a bargain at 600 bucks. I was going to buy them tomorow but I will be doing alot of driving in my car in the next 6-8 weeks so it would be good if i could pay 68 bucks for a full tank and have it last more than 2 days.
Alternatively I have a set of Tein HR coilovers I want to be rid of. They are height adjustable, but not bound adjust. They are a very firm ride, and not suitable to what I use the '33 for. I just need some stock susp in the mean time till I can afford the bilstein group buy. Im not into drifting, but good hills runs, so the tein's must go. Red or Paully, Im after $800 + your stock suspension. PM me if you are interested :blink:
what does bound actually do, i know(think) it changes the sping compression height? is that all so that when the car hits a bump there is less or more travel in the spring
does this = a better ride if you make more travel in the spring ... hope this makes sence and isnt the ramblings of a mad man :blink:
Sorry, I should have said they are not DAMPER adjustable. Damping is in bound and rebound, thus bound was the first thing that came to my head :blink:
So the Tein HR's are height adjustable with C Spanners (which are included) which changes the spring height. Damper adjustment is internal in the shock, basically changing the valving as to how quick the oil/gas can move. the less it moves, the harder the ride, the more it moves the softer the ride. Thus the "clickable" adjustment on some shocks/coilovers.
Yes, bound (more commonly known as bump) is the compression stroke of damping. I think there has been confusion caused by some people (sponsors) selling coilovers that dont know what bound is...
$600 for those Bilsteins is a bargain, I paid $2200 for similar stuff through the group buy. Who ever buys them will not regret it...
Edited by salad
i dont belive the bound your talking about is damper
look @ the top locking nuts below the springs that is what i was trying to explain with the amount of travel the spring has
32 Step Damper Adjustable
* Precise control damp valve
* Operates smoothly on all road surfaces
* Expansion/Suppression of shock adjustment
Ride Height Adjustable
* Full length height adjustable
* Bound adjustable with separate spring locks
* High quality T6061 aluminium alloy used for all adjustment locks to provide a lightweight design that holds spring and vehicle down force
ISC Coilovers
That is the person/sponsor that I was talking about. He is refering to preload.
The amount of travel the spring has is pretty irrelevent to spring seat location as the bumpstops will stop travel before coil bind becomes an issue, unless the coilover is really crappily designed (spring and spring seat height).
Edited by salad
Does anyone out there know how to adjust power fc settings throught the hand controller? Every manual and document i find is in Jap.
I am also interested in getting the FC edit program to work so i can adjust settings on my laptop as the version that was emailed to me via an anonymous source last year wont seem to install. Cubes any ideas???
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
