might be off topic here ...but was there much drama's fitting the kit in? ..i upped my stocko cooler to a r34smic unit ..but to be honest..i dont think this was a worthwhile upgrade as i cant feel any increase in power...and after some stop start traffic..the car still has the same sluggish performance from heatsoak...so im thinking of getting a china cooler kit.
agreement.
I used a R34 smic for a no more than a handful of months
I dont think its a worthwhile 'upgrade' at all. Only if you need the vehicle to 'look' 100% stock
But then again, if you must have a smic, go for an ARC brand (off ebay) side mount. bees knees right there
how is it getting heat soak in stop start driving? there is no load on the turbo unless you drive like a madman between lights and it is not located above the engine (ie top mount)??
when you go to a front mount all the same engine pipes will heat up and probably more so on the cross over pipe.
the R34SMIC runs out of cooling ability under load but stop start it should be no issue.
i agree there's no load on the turbo, but somehow i guess even on idle the air has to pass through the intercooler...and therefore i suspect that the small r34 smic just does not have the capacity to cool down the airflow.. its not like massive power loss...but just that i dont think the cooler works on boost pressures above stock....those that have used the stock s1 coolers and "upgraded" to the r34 unit will definately know what im talkin about.
agreement.
there was an ARC FMIC that sold on the japan auctions for less than 30K yen.....still kicking myself for not placing a bid
I used the R34 side mount for some time and was quite happy with it. Although I did have a descent air feed and the intake shroud for it. It doesn't flow as good as a FMIC (going by the fact I had to turn my boost down after fitting the FMIC). I have to admit the current reason I went for the front mount was because of the Nismo kit I'm about to get fitted. It would look really stupid with a big gaping hole at the front and I HATE mesh (way to rice for me) but I also plan more mods down the track so it will pay for itself then.
I used one of the GKTech kits (was cheaper than a Just Jap delivered) and was pretty happy with it (bar the clamps, but you get what you pay for) the piping was spot on and the cooler itself was nicely polished and no ugly weld or patch jobs with good mounting points. The brackets are spot on too (unlike the Just Jap kits aparantly) and allow you to shift the cooler side to side when they're loose (becuase it probably will need to be just a little when the new front is on). You do have to cut a hole under the battery but this is done easially with a 3" hole saw and some rubber tubing to protect it. And contrary to popular beliefe you DON'T have to cut the bloody fan blades. Take a good long look (this goes for a lot of work shops out there too) and just cut the hole under the battery a little further back and drill another hole about 10mm back from the last one on the bracket that goes to the tappet cover. BINGO you blades are no where near you fan. Also will need to trim just a little off the front bar support. I sat mine a little further back so I (a: didnt' have to take as much out of the front support and (b: becuase I cut the hole back further the move the cross over pipe back). You'll also need to trim a fair amount of the front bar but this is a piece of cake. All in all it took me 5-6 hours or so. Could do it in less now.
If I had to do it again I'd use another cheap kit, but look out for dodgy ebay ones as a mate got one which was meant to be brand new and the core had been repaired. I'd stick to either GKTech (can't go past the price) or Just Jap.
Very sorry about the off topic rant, back on now :):thumbsup:
For those wondering about fitting Josh has answered most of it i think. I know what you mean about the heatsoak. S2s come with R34 coolers as standard and they dont provide the cooling capability of a large front mount. Theyre fine for stock boost but suffer on 10-12 psi especially in hot weather. With a front mount its like driving on a cold day every day!
I got a cooling pro kit which has two pieces for the piping coming off the j-pipe past the radiator fan whereas a lot of others are a single piece.
Fitting was not too hard at all, just time consuming.
For the install you will have to cut a hole under the battery, Cut two little lines into the bumper iron and bend the metal up to fit the cooler behind. This allows the aircon fan to stay.
If you have a stock trans cooler you will have to remount it closer to the radiator. I just hacked up the original bracket with a grinder, pretty easy.
I also dont think you have to cut the rad fan provided you have cut the hole under the batter right and angle everything correctly.
I have the dayz front bar and only had to cut two little semi circle pieces out of it to fit the cooler pipes behind.
If you do have any questions im sure we can all give you answers. I was actually putting off the kit because i was worried about the hassles of installing it but it wasnt that hard really. Also ill take some pics once ive cleaned up the car and it stops raining :]
Edited by GorGasm
i have been there done that with both R34 SMIC and a Trust SMIC.
stop go = no issues (from my experience). due to a relatively average/poor hiflow (ie non-GCG) meant lots of hot air at higher boost levels and this was a challenge for them. i would have the Trust one back in heart beat with a decent hiflow.
Edited by wolverine
Very neat install. I have to admit the kits aren't anywhere near as hard as i would have thought to install. Just got to make sure you leave yourself a descent amount of time. Love the RACE BLING radiator cap too... And I'm still debating wether to install a oil catch can, when I removed my old cooler there was stuff all blow by residue in the pipes or the cooler, so I don't think I'll worry for now. But the do look cool :huh:
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
