G'day guys, i own a ca18det 180sx.
i need more ideas of how to fix this problem, basically car won't stay running without my foot on the accelerator, and when i do it won't rev pass 900.
i've changed the spark plugs, test the coils, did a compression test (all good), cleaned the most of the adaptors.....
is there anything else i should do to to get this car on the road again?
https://www.sau.com.au/forums/topic/163986-car-wont-rev-help/
not wanting to sound rude but what could be wrong with the afm? i did took the thing off and gave it a quick cleaned, and from inspection,i thought the thing doesn't have too much mechanical components nor electrical components for it to be related to any problem.
as for the intercooler, while carbie cleaning the throttle body, i did took some of the IC pipes off to clean off some of the oil, i remember i did tighting up all the clamps but will pull it apart and pull it back together again tomorrow.
uummm at this point i gonna say no to a new comp :) wallet is quiet empty now after easter.
by any chance could be related to the crank sensor?, cos i got it replace a few days before this rev problem
This happen a day after i degreaser the engine, but i did took the car out after i cleaned it, and it was fine
Edited by dOOb
Check your intake piping, I popped off a pipe today and it did exactly as you described it. Won't rev and dies if you lift the foot off the accelerator.
took all the pipes of today and put it back today nothing change so................
Is the CAS tight?
It might not be on tight enough and the timing is way out.
Check your connections on EVERYTHING electrical too. Just unplug them, and plug em back in.
........i messed around with the crank sensor, i didn't take it off just losen the bolts and turned it in both directions a lil bit at a time. NOW THE DAME THING DOESN'T EVEN KICK OVER.
CAS was tight, timing is okay after i changed the crank sensor, i've already unplugged most of the adaptors and cleaned it with carbie cleaner.
ANYBODY GOT ANYMORE IDEAS?
Edited by dOOb
try a fuel pump. i replaced one in a r33 that was doing the same thing fixed the prob
i checked the fuel pump when i changed the "O ring" on top of the fuel tank about 6 weeks ago, fuel pump looks to be near new, also checked the fuel pressure and thats okay aswell.
thanks for that tip SXC_R33, can anybody think of anything else that is causing this problem?
+1 afm is stuffed actually a really common failing part and it wuold make the car not run past about 900rpm but you should be able to start the car fine, try starting the car with it unplugged if its worse its probably ok but if its the same then it could be stuffed
its entirely possible that its the AFM as stated, and because its been running rich for so long you have simply fouled the plugs...
i'd say get a new set of plugs ($20 all up for NGK copper BCPR6ES) and get a hold of someone's AFM
change them both at the same time and see if it kicks over and runs ok
hope that helps
seeing how i've stuffed around with almost everything i can think of, next will be the AFM, will try it unplugged or swap it with a mate.
hope that helps
i've already changed the plugs when this problem first occured, but that didn't much to it but might changed to those recommended to see if theres any different.
yeah but what i'm saying is that the AFM is the cause, and the plugs are fouled because of the AFM
so a new AFM might fix the cause, but the car might not start still because the plugs are foulled
you have to fix the cause (AFM) and the effected parts (plugs) at the same time to see if this is in fact the case
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
