RB20DET silvertop, 700*300*90 front mount, re-cirulating BOV, K&N pod filter, 3 inch custom mandrel exhaust, HDI electronic BC, monroe GT gas shocks on lowered king springs, 15" hyper fang rims, 6 puck extreme clutch, machined flywheel, R32 Gts-t gearbox, Whiteline sway bars front and rear, nolathane bush kit, Elevo deep dish S/wheel, SAAS boss kit, DBA slotted front rotors, bonnet pins, oil catch can (not fitted), interior is in excellent condition, exterior needs some attention, recipts for most pajor purchases and car has a sound history .
Car is registered, roadworthy and legal with modification plate.
Open to offers
Hobart TAS area, willing to deliver in TAS or pickup.
0400392991
https://www.sau.com.au/forums/topic/163988-1987-r31-silhouette-rb20det/
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
