Hi guys,
got my hands on a set of Advan A048 semi slicks and i was just wondering what these would be like on the road for lets say daily driving.
anyone used them or similar semis on the road?
just wondering coz my tyres are nearly worn and if they will do the job, may as well put them on.
Thanks
Stel
https://www.sau.com.au/forums/topic/163997-advan-a048-semi-slicks/
  • Replies 40
they are fine for road use. very soft tyre though so will wear out quite fast. the only problem I've ever had with them on the road is when they were fairly worn they were horrible (dangerous) in the wet. when new though with lots of tread they were not bad in the wet.
Hi guys,
Thanks
Stel
they have been my daily driving tyres for 2 years
i <3 them! will never go back to normal tyres
hmm weird this richard. i find them rather nice in the wet. compared to when i had the 34 wheels on with falken azenis (non semi ones)
I used to use them on my daily driven J31 maxima. I found them to to be pretty good with the suspension I had in the car. I agree with baron though once they get down on the limiters they are very poor in the wet. Id generally use them till they got a bit low then put them onto the Silvia and get a few hard laps out of them before they were absolutly worn out.
Compared to the RE55s which I now use on my GTR the Advan was a much better tire when new but faded away quickly after a few cycles. As a street tire the RE55s will last longer and you wont notice any difference in performance.
Cost wise the Advan is typically 50-60 bucks more than the RE55s.
If you need the traction then they're good, but otherwise I wouldn't suggest it on a daily driver.
Ignoring the wet weather grip (I found the A032Rs I used to be quite reasonable in the wet), the tyre roar will give you headaches. Turning up the stereo didn't help me much.
The lack of tyre life is also a concern, if you're paying for it.
That and, if you get pulled over, the cops assume they're not street legal and you have to spend time explaining it to them. And once you do tell them its "street legal race rubber, like on tarmac rally cars", inevitably your bonnet spends a lot of time in the "up" position while the cops try defecting you for something else.
Put these on today, noticed a big difference in traction...even in the wet suprisingly (my old tyres where shit so not that much of a suprise).
With the old tyres, i would spin in dry weather once i hit about 4.5k to redline in first gear, with these there was nothing.
As far as noise goes, they dont seem to be too bad. I can't hear them when the car is in gear, but when i put the clutch in i can hear a slight sorta whine. Not too loud to make it a problem.
Thanks for all the advise.
Edited by Stel
In my experience, the tyre roar becomes noticable above 80km/hr. The Falken RS-V04s sounded like a low flying prop-aircraft from 60km/hr. The A032Rs only got noisy at about 90km/hr. The D01J's on a mate's S15 started humming at 80.
Either way, it makes the commute to Wakefield Park an absolute pain. :blink:
if you put them on yesterday how have you sampled their wet performance? I didn't think it rained anywhere in sydney yesterday? lol just struck me as odd.
It rained in my area last night. Im in Beverly Hills/Kingsgrove.
Some technical stuff.
A048R’s are the control tyre for a number of CAMS circuit racing classes, Combined Touring and Improved Production being a couple of them.
They come in two “compounds” (medium and medium/hard), although Yokohama Australia swear that they are both the same “compound” but with carcass differences. Both compounds are not available in all sizes.
The range overseas is greater than what Yokohama bring to Australia.
They have ~5.5 mm tread depth compared to ~8 mm that you find on most normal road tyres.
They have the normal wear bars at ~1.5 mm tread depth
The lack of useable tread (5.5 – 1.5 = 4 mm) compared to normal road tyres (8 mm – 1.5 mm = 6.5 mm) means ~40% less tyre life.
It also means less water dispersion in the wet, which just get worse as they wear.
The tread compound is 40 to 60 duro, road tyres are typically 100 plus.
The soft tread compound, compared to normal road tyres, means ~30% less tyre life
So if you get 25,000 k’s out of normal road tyres you can expect to get around 8,000 k’s out of A048s.
They are VERY critical on alignment, for example too much/little camber will wear them out VERY fast. So make sure your wheel alignment settings are spot on for your usage patterns.
:) cheers :thumbsup:
  • 3 months later...
Sorry to dig up an old thread
but Im also interested in some more feedback on how these go for road use
Im aware of the noise and wet weather grip when low on thread
but considering these are OEM tyres for lotusses it cant be all that bad for road use, right?
Im particularly interested if these tyres heat cycle as much as the RE55S
anyone with experience with these tyres able to compare them with RE55S or R888 or DZ03?
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
