The A048's are the worst for heat cycles. If they are going to be used for regular track work as well they only have a good 10 or so heat cycles before they really harden up. This fact makes them probably a longer lasting street tyre however. I've used one set and won't use them again.
The Dunlops seem to be the best but are $$$ which is why I use the RE55's which are pretty awesome at everything. The Toyo's have amazing grip from cold compared to the others but not as much grip when hot.
  • Replies 40
One other point people may like to note is that the RE55's (Bridgies) make an absolute bucket load of noise on the road. The Toyo's (RA1's & perhaps the 888's) are, by contrast, civilised.
Yeah the road noise really gets to me at 6am drives to Winton :D .
I wouldn't use it on a daily driver, especially before the tyres warm up, the grip is worse than my street tyres.
Edit: Im using RE55s.
Edited by Yawn
every tyre 'heat cycles' I think what you actually want to know is does a tyres performance drop off after a number of heat cycles and the answer is yes, all semi-slicks are affected by the number heat cylcles they are put through. some worse than others, but they all are in some way.
A048's are the worst for performance drop offs after heat cycles. They really do go rock hard.
The Toyo R888's are excelent for road noise compared to the others. I'd use these if the car was seeing more street time than anything or if the motorosport I was doing was primarily auto-tests / hill climbs.
But for a track day tyre I'd use the DZ03's if I could afford them. But I can't so I use the RE55's as they are the next best.
Do you remember which compound of A048 you used, Snowman?
was it Medium (M) or Medium-Hard (MH)?
yeah. i used to use the ute ones. we have a large stack of them all with abot 1.5-2mm left on them. generally this amount lasts about 2 weeks of normal driving up and down the m2 before they are completly smoth.
pretty scary but. not bad in the rain. but at 300+ a tyre its just not worth it. thats what the spare rims with propper track rubber is for :down:
gordon should have been happy then, thats 3 categories in nsw using them as control tyres. Shame they suck - utes used to run on basically a road tyre compound so its not wonder they are going better now - but the dunlop dz03 and bridgestone re55 are still at least a second quicker.
Haven't tried the toyos myself but they are getting a good wrap atm.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
