Hi all,
Been playing and wanted something different for my car so decided to do an LED conversion on my R33 Rear Lights.
It's something I started as a hobby as can be seen on gtr.co.uk - although it's turned into a group buy in the UK.
Just thought I'd share my results and ask for a little feedback on the conversion - It's meant to be a little Z-Tune-ish style.
It may sound strange but there are over 800 LED's in total across the back of the car!
Anyway, opinions?
Oh, almost forgot, there is a Fog Lamp on the outside of each Reverse Lamp which wasn't wired up when the Vid was taken hence why there only appears to be a small Reverse Lamp.
Cheers,
Matt.
Edited by Matt J
https://www.sau.com.au/forums/topic/164013-r33-led-tail-lights/
i cant see any difference? oh its a video... dont mind me :P
i was thinking about getting some LED rear lights and swapping about 10% of the Red LED's for blue ones to give it a unique tinge... i might still do that... have those ones on a switch though, as police around here are nasty...
im thinking about doing what you did with the front lights too :(
yeah im a big fan of it... how much did the lights cost you in the end?
im thinking of getting some BMW ones with angel eyes but i think they are a bit big for the skyline headlight...
The headlights cost me about £500 in parts as they are 2 sets of Bi-Xenon projectors etc.
The BMW Bi-Xenon units don't fit as the solenoid is too large.
I found the Audi units fit with no problems...
thats so hot ;)
wanna...... give em to me??? :)
or give me some info as to how to do it? and do those have angel eyes?
Developing the brackets that use the original mounts was the hardest part - they took a while and a bit of head scratching to get right.
Using the original mounts means the beams can be adjusted as per the standard headlights.
They don't have angel eyes, I do have 2 sets which I was going to install but they aren't to my personal taste really.
The conversion is actually very simple once you have all the parts and they took me about 4 or 5 hours from start to finish.
The main fuse has to be uprated from 10 or 20 Amps (Can't remember off the top of my head) to 30 Amps as the start-up draw current is quite high having twin sets.
Matt.
i so wanna have a go at something like this... but i dont really have the cash flow for it at the moment... or a spare set of headlights :P
either way, the modification bug has been biting me really hard lately... i have to do something original (or rare) or im gunna die!
ill try and find out prices for headlights like these, but im sure i won't be able to afford it for a while... too much other stuff going on :O
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
