Hey guys,
This is my first post here in the NA section and I was wondering if you could help. I have had conflicting reports about which oil filter bolts up to the neo RB25 and was after help. Is it a Z145a like my previous car or is it a z442?
I was told that after the 11th month 98 the 34 switches from 1 to the other but I need someone who owns one to tell me which one they use.
My car is a 1999 r34 GTV if this helps.
Edited by smurf80
https://www.sau.com.au/forums/topic/164023-r34-na-oil-filter/
Z145A fits, but you ought to be running the smaller Z442 (or Nissan part# NI-15208-53J00).
Best thing to do, is goto Nissan, quote your VIN number and they'll look up what filter you need in their FAST catalogue software.
I always used the 145a....but recently someone bought a filter for me and got the smaller version, I can't see how something that tiny doesn't block quicker...in my opinion I like the ol' 145a as it's easier to grab when changing :P
Possibly.. but they ran Z145a prior to 11/98, then Z442 after - all on the same NEO motor. Maybe something else changes with the post 11/98 models... heard later models have GTR cams but I can't verify without opening mine up.
  • 3 months later...
i have a r34 99 gtt i recently did a oil change according to specs book z422 the smaller filter is the correct one...... i opted for the z145a as said it seems to fit the same and is bigger easier to remove.....does anyone know the actual reason for goin the smaller filter??? my car also had a z145a when dealer/importer did oil change.......
Edited by rgr34
i think the smaller filter prob has a diff filtration rating (ie diff micron size)
if it helps, my boss runs 3 cars in the AMCA series over here in WA (like super sedans - Holden 253's on custom body's) and they run methanol, around 11:1 comp, wild cams and they use the smallest oil filter i have ever seen...
The bigger the filter the less restriction through the filter obviously, on an NA its not so critical, but on all our race cars we try and get the biggest filter possible on them..., they are all essentially the same, there are a couple of different thread and oring sizes but essentially if it fits it will work... If you've got anything floating around internally that u need an oil filter to trap the type of filter your using is the least of your worries... your biggest concern is the cost of the rebuild...
    • I'll tell her I put in a new air filter on it, which, it would have anyway with the ITB's In the end she isn't to fussed, she spends lots of money on hair, nails, make-up and all the other "required" beauty products that women use, plus I grease the wheels with shiny gifts and holidays wherever and whenever I can She once questioned my car spending "budget", but after itemising everything she spends on herself, and what I spend on her, and the fact that I don't care if she does or doesn't wear make-up and fancy pants perfume, or requires new outfits for every wedding, funeral or anything else she deems worthy, and I'm quite happy to go "real" camping, instead of staying in hotels or jaunts on cruise ships, she decided not to press the subject on how I spend funds, and has never asked "how much did that cost" again, so a win to me And how often can you say you really get a win with the fairer sex? She is a good woman, and in the big picture, I'm really lucky.....that she hasn't killed me yet
    • What will you do when the Minister of War and Finance says the intake noises are too loud?
    • Will the clear coat dissolve the ink tho?? I thought about clear vinyl tape too. Thinking what to do haha. The one I have now is cracked in 1 spot, otherwise mint. Plus the MINES one is much thicker plastic material so its not flimsy at all.
    • No. Go a different colour, and just trim it at an edge line. Even manufacturers do different panels different colours etc.
    • I see no real downsides to ITB's, apart from the initial cost of my drive in drive out lifestyle, the "upsides" is they sound cool and would add lots of smiles I am willing to pay to play for the extra smiles I've spent the morning googling and youtubing the BBR ITB's, a "little" extra power and throttle response, but alot more dort, and really, I'm only really in it for the dort Who knows, after all this money is spent I might even make 150kwatw....LOL
