I'm almost ready to buy a stagea, i'd say in the next month or so definatley.
i dont think i have enough money for compliance at the moment tho. but can afford the car and all the costs to get it here.
can i still import the car, get it home keep it there untill i can afford compliance??
and anyone got a rough guestimate on compliance cost for a 1999-2000 stagea?
Cheers
:dry:
https://www.sau.com.au/forums/topic/164030-importing-question-compliance-etc/
yeah i thought so.. 1% rise is only really 50 or so bucks so waiting for the dollar to move isnt really that cost effective
i might post in the stagea forum. about cost of compliance. i budgeted around 4-5k....
Edited by Angus Smart
Although there's a time limit on compliance, most RAWS require you to bring the vehicle once it's left the docks because if the car isn't being complied, that's one less plate available to them.
Try the Imports101 website. It has a good cost calculator that actually includes all the necessary items for your state. (Whatever that is).
You may be surprised by how much difference to the end result the change in the value of the yen makes when it goes from, say 96 to 97 to the dollar. It works out to be quite a bit more than $50....
Buy one locally in aust now i reckon, prices have plumitted. Plus unlike the experiences i had, you can see and drive the car, take it to a mechanic and all other things before you buy it :happy:
Otherwise you might get the "one-in-a-million" car with a f**ked engine like i did :dry:
To be honest the calculator is actually pretty good. But at the end of the day it is only as good as the accuracy of the FOB price you put into it.
Unlike alot of calculators the Imports101 one lists all of the stuff you will end up spending money on. It doesn't neglect stuff & assume you live in Queensland (Which is the cheapest state to get an import into)
yeah i understand the whole try before you buy here. but there isnt too many leather stageas out there for under 18k and thats what i want!
yeah looking at the calculator it does seem good! minus the 600ish for their fees :P
You need a permit from FORS to import it, it would be a prohibited import without one. they only cost fifty bucks, but they can only be issued to a RAWS for post '88 cars- most will want a deposit as well, usually around a grand. Stageas are around $2500 + tyres to comply, depending on the RAWS and how much extra work hasto be done, like remove/refit mods etc.
Bikkies you might want to update your info before you post. FORS hasn't been around for years and aren't responsible for issuance of the import approval.
DOTARS then- force of habit from having to deal with the sods for years- went through all the rigamarole to get low volume certification on SWB V8 Land Rovers, took four years and about 100K then the arse fell out of the dollar. Not my favourite organisation.
    • Here is a recipe. Sonic blocks till you get one that has a good enough bore. Get a torque plate and block brace, use your choice of fasteners (arp ect) bolt the thing together empty, half fill it and let it cure. Release it when it has, go to a REPUTABLE RB Builder and get the thing line bored/honed and cylinder honed to size, then wash. Once its all clean and dandy, wash and blow it out again. Then again.  Assemble said engine to your desired clearances with oil control mods, gasket to suit desired CR/Squish ect. Attach your extended sump with proper trap door oil baffles and head drain plumbed to sump with a SUMP BREATHER SYSTEM. Build your front diff with a decent LSD, rebuild your transfer case with a few extra plates, more than likely replace your tailshaft centre bearing and tighten up the rear diff. Tune to minimise excessive midrange cylinder pressure (timing unless you like to split bores and rebuild engines) Enjoy your engine, but hate the fact you are now destroying engine mounts, gearboxes, gearbox mounts, diff output flanges and driveshafts, diff mounts, tailshafts and front CV's.   Disclaimer.... Ive never done any of the aforementioned stuff.......
    • 440s will support well over 400HP on petrol, which is a decent place to be for an RB20. 230+rwkW. Will be a safer bet for idle/low load. 550s would be nice for the extra headroom. I've made the same decision with mine (Neo25). 1000s are probably too big for the Nistuned ECU, so I have some smaller ones.
    • Appreciate everything guys. I did go ahead and get an alignment... most of my complains are solved. Car is not perfect, but it's good enough. If I notice uneven tire wear or anything I'll just take everything back to stock.  Thanks again!
    • They still have not shipped the 550cc injectors as they weren't in stock, so in theory I could ask to get the 440cc ones instead, if those work better in my scenario. They're the same price so really shouldn't be an issue. Unfortunately I am not so knowledgeable in most parts of tuning so I wasn't sure what's best to choose between the two. 440cc ones are the lowest they have (not in stock, but available to buy nonetheless).
