hi everyone,
this is my first post so plz forgive me if i've posted in the wrong section or smth like that :P
i was just wondering abt smth:
i've wanted to get a r34 skyline for years now (since i first saw them in yr 9 haha!)...except i dont reli want a turbo
is it possible to get the r34 rb20DE here? i did a bit of research n i think the r34 comes with the rb20DE NEO rite?
hehe anywho wud greatly appreciate any help n suggestions, opinions here...
thanks!
https://www.sau.com.au/forums/topic/164063-available-r34-rb20de-neo/
haha abt how much wud a 2 dr r34 non-turbo cost?
i want the looks of the r34 without the fuel consumption of a turbo :P
best of both worlds lol
btw, reason i wanted the rb20DE NEO is cos its sposed to be the most fuel-efficient skyline every made haha
but i'm sure the rb25DE NEO wudnt be much worse on fuel rite?
Edited by ConverT!
you also gotta think about insurance. oh and also.. think about "the bug" turbos take to mods wel... and you can feel most of the results quickly... and you might get the BUG...
so if non turbo is the way.. then stick with it.
But if you think you can fight "the bug" and you can pay the insurance.. then go the turbo and drive nice.
oh and buy my auto
If you get a non turbo you will still go power hunting within six months, doing extractors, a noisy exhaust, pod filter. All giving you little joy for your money. Once you get sick of that you will start looking at putting a turbo motor in there. No one can fight the "more power" bug. NA should just stand for not available. end rant.....
the R34 with RB20DE NEO isn't eligible for import into Australia hence why you haven't seen any in import yards or import brokers e-mail distribution lists.
the reason why? (from memory) it did'nt meet power to weight ratio requirements set by Aust. Govt.
  • 3 years later...
Yeah dude you can get what your looking for!
i recently just got a Non turbo 2 door r34 25GT from an import car yard for 15 grand
so yes the r34 25gt's come with a RB25DE NEO there fuel consumption is the best out of all skylines in does 9.4L/100kms
Lol internet stats lie to you ^
I have an R34 GT, used to have an RB25DE Neo, recently put an RB25DET Neo into it. I am getting the same fuel consumption with the turbo as I was with the non-turbo motor, both are getting about 350-400kms to a tank depending how I drive. The 25DE motor is high compression so it uses a lot of fuel anyway. Just get a turbo.
If you want good fuel consumption get a hybrid, Skylines are high performance cars. You're not gonna get good mileage from them.
i didnt think the r34 came with an rb20de neo stock?
am i missing something i through only the r32 had the shitty rb20 :D
just buy a turbo... i got a big aftermarket turbo and still get near stock if not better than stock fuel consumption
My 34 sedan is rb20de Neo >_<
time for my 2cents, i'd advise you go turbo becasue of all the above mentioned reasons, the only way you'l get better fuel economy is if you improve the power to weight ratio (make your car lighter) ive got a R33 gts-t and for a large majority of the time i drive off boost and it realy doesnt chew the fuel at all! i get 400+km's to a tank (460km's was my absolute best >_< ) ive removed my spare wheel and my sub to reduce the weight and im looking into removing more unnessisary things. best way to go about it
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
