there are 2 different ones.
the steering rack bushes (there are 2 on the rack itself) and steering column bush (there's one just up from the uni joint on the column)
I've just changed the rack bushes as i had a spare 70 bucks and a couple of hours to blow over the long weekend. Haven't driven it yet though.
the uni joint steering spacer is a really good mod. your turn in feel is highly improved and as is steering feedback and response.
you will get a bit of power steering noise but it's only when parking. If your wheels are not ballanced you will feel it right away with the spacer fitted.
Drifting the car is a lot more enjoyable with this spacer fitted.
hmmm interesting, anybody know who was running that group buy for the spacers...seems to have been deleted....
also who makes heavy duty rack bushes, can't seem to find anything about them in the whiteline catalog....
  • 1 month later...
There are 4 bolts accessible from under the car that hold the syrups over the rack. undo those and a couple of smaller bolts on heat shields and odds and ends to get some room. the old bushes will probably fall apart when you try to remove them. Installation is the opposite of removal.
It's an easy enough job, just a pain in the arse location to work.
  • 7 months later...
I realise that this is a little old, but I am interested none-the-less. BHDave, you say that installation is the opposite of removal, but the removal process involved the old bushes falling apart! Do the new bushes slide on from each side? Does that mean you need to take the tie rod ends off? Alternatively, do the new bushes have a slit in them to allow the bush to simply slide onto the rack? Any info would be good. Also how long does the job take?
The D project ones i use have a poly bush on one end which is slit so you can slip it over the rack and a 2 piece one for the drivers side which have steel inserts with fairly stiff rubber on the outsides so you can slip those on either side of the rack and then seat the whole thing back down and put the stirrups (dunno why it says syrups earlier in the thread :) ) back on.
All going well under 2 hours.
BHDave, I went with the Drift Motorsport ones too, but I have found after alot of pushing that I can't seat the rack to seat properly. The new bushes seem to be too big to get the styrups over - the drivers side one won't even go around the new bush.
Did you find that it was a very tight fit on the way back in?
sam5709, how much did you pay for the Superpro bushes - Supercheap Auto quoted me $210 for the two which I thought was steep compared to the $80 delivered I paid D Project and the $35 that Nissan want for the stock ones (part numbers 54445-05U00 and 54444-05U0)
Edited by Birth
depending on application you can get ones that move the rack closer to the x-member to stop over extension of the arms during drift etc.. uras do them as do a few other manufacturers... the Drift Motorsport ones are excellent value... but im suprised they dont fit ^^^
Have u got the bush in round the right way? If you cant sit the rack down it sounds like something is off...?
I cant remember when i did mine, but from memory the stirrup pulled down onto the new bush a little.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
