900hp Out Of My Rb25
Ha ha ha mine isn't your average berlina buddy..... do your homework. :)
ahh so you completey redesigned it make it jap or euro :thumbsup: re-aligned all the panels, fixed the electrical gremlins, removed the 30 year old irs setup and fixed the chronic steering shudder isues :huh: i love my holdens, at least having LS1 edit keeps me busy.... the engines are great. just stirring ya buddy.
Edited by URAS
  • Replies 82
yeah i wan2 to see some dyno sheets and mod list cause those are pretty far out claims... especially with 101 working on you car they'd be lucky to get a 20hp gain let alone those figures
Your a fool :(
Hell didint they even make Jesus walk on water and change water to wine to prove his claims? Surely if Jesus didint mind proving himself you shouldnt.
-Sayajin
Wheres the proof Sayajin?
On a more serious note though martin the pose you struck in Hot4's magazine left many in doubt about your sexual orientation, what do you have to say for yourself?
Nice work bud :wub:
that pic in fast fours was pulled from the ignition dvd when i was leaning agasinst my car and yep its a gay shot...lol and with the commodore line i have a commodore 04 monaro it was just a figure of speach here are a couple of pics... just a few mods more pics to follow
tomei crank
tomei rods
tomei pistons
tomei rings
ati balancer
external dry sump system
2mm ferera over size valves
ferera double valve springs
tomei cams 270m x 10.5 lift
solid buckets
custom lifters
greddy plenium
100 mm throtle body
1000cc sard injectors
zex direct injection nitros system
motec m8
msd digi 4 ms blaster coils
custom sump
are custom intercooler
2 speed power glide with trans brake
and the list goes on..........post-7531-1176375946.jpgpost-7531-1176376015.jpg[attac
A real 900hp RB25.. hmm is that sort sort of world record?
I haven't seen one like that in Australia before..
this machine is awesome!
I'm curious: did you lie awake one night and think,
damn those GTR boys and their huge power figures..
I'm gonna scare the pants off them by building a monster that will pull
soooooo hard that the Earth changes its orbit?
It just goes to show what you can do when you get serious about doing something.
Good on you!
 Share
    • Hi all,   I have been a member here for years and am back to owning an R35.  It's my car and thought members of the community might enjoy sharing my journey.  I am definitely here to join the conversation.  If sharing this content isn't appropriate or it belongs somewhere else, I am happy to have it deleted or moved...
    • Data looks rock solid? I'm assuming you jabbed the throttle twice OR once? the TPS voltage moves up and down twice, however you've mentioned you did it once.
    • Having not watched the videos, I'm unsure, but this may be better suited to the importing thread?
    • Update on this situation: (Forgot to put in my previous post that I bought another brand new pressure gauge and fuel shows the same 50psi) I've deleted all the aftermarket immobilizers and turbo timer shyt and placed all factory wiring back to normal. The problem is still the same and nothing changed, but atleast it's a bit more tidier under the steering wheel. I've also siphoned out all the old fuel and then poured new batch of BP98 fuel (about 15L) into the tank. Nothing changed. Still the same idle. I also changed out the MAP vac line with a new one and, still the same.  So 2 days ago, I thought fk it. I'll just change out the fuel rail and injectors with another set that I know worked well in my brother's R34 a while back. That other fuel rail has the exact same Xspurt 640cc as what I have right now. So I changed it out to that other fuel rail and injectors (new O-rings) and injector harness. Put everything back together, started the engine, 464906286_1624569924763105_5179888796065901094_n.mp4   and yeah... still the same 50psi and idle problem. 🫠 I can also hear each of injector's solenoids running when I put a screw driver to it and have the other end to my ear. I might get a noid light just to confirm pulsasion but yeah, very strange that both fuel rails and injectors put out 50psi.  31-10-2024.csv I've attached it here. I started recording, then started the engine and let it idle with no throttle, then at the end I applied a little throttle and then stopped recording.    So, now idk. I'm going to see if swapping out the brand new R35 coils to my old splits fires will change anything. 🤷‍♂️
    • Hey mate, nice work on the car. Just a quick note, people generally don't like it when you use the forums to dump and run to advertise your YouTube content. If you're gonna stick around and join in the conversation then great, but if not this might not be the best place for you.
