900hp Out Of My Rb25
Ha ha ha mine isn't your average berlina buddy..... do your homework. :)
ahh so you completey redesigned it make it jap or euro :thumbsup: re-aligned all the panels, fixed the electrical gremlins, removed the 30 year old irs setup and fixed the chronic steering shudder isues :huh: i love my holdens, at least having LS1 edit keeps me busy.... the engines are great. just stirring ya buddy.
Edited by URAS
  • Replies 82
yeah i wan2 to see some dyno sheets and mod list cause those are pretty far out claims... especially with 101 working on you car they'd be lucky to get a 20hp gain let alone those figures
Your a fool :(
Hell didint they even make Jesus walk on water and change water to wine to prove his claims? Surely if Jesus didint mind proving himself you shouldnt.
-Sayajin
Wheres the proof Sayajin?
On a more serious note though martin the pose you struck in Hot4's magazine left many in doubt about your sexual orientation, what do you have to say for yourself?
Nice work bud :wub:
that pic in fast fours was pulled from the ignition dvd when i was leaning agasinst my car and yep its a gay shot...lol and with the commodore line i have a commodore 04 monaro it was just a figure of speach here are a couple of pics... just a few mods more pics to follow
tomei crank
tomei rods
tomei pistons
tomei rings
ati balancer
external dry sump system
2mm ferera over size valves
ferera double valve springs
tomei cams 270m x 10.5 lift
solid buckets
custom lifters
greddy plenium
100 mm throtle body
1000cc sard injectors
zex direct injection nitros system
motec m8
msd digi 4 ms blaster coils
custom sump
are custom intercooler
2 speed power glide with trans brake
and the list goes on..........post-7531-1176375946.jpgpost-7531-1176376015.jpg[attac
A real 900hp RB25.. hmm is that sort sort of world record?
I haven't seen one like that in Australia before..
this machine is awesome!
I'm curious: did you lie awake one night and think,
damn those GTR boys and their huge power figures..
I'm gonna scare the pants off them by building a monster that will pull
soooooo hard that the Earth changes its orbit?
It just goes to show what you can do when you get serious about doing something.
Good on you!
 Share
    • Oh, yeah, no arguing that the duty cycle is different. And a circuit car will go to those speeds for more distance and longer times. But, I suspect that if a tailshaft has a harmonic problem, that it would cause damage and shit itself maybe even on the first pass. A second or two of running at the resonant/harmonic problem speed is already a couple hundred revolutions.
    • Shaft speed would be the same, however it's how long they hold it there for and repeated conditions. FWIW half way down the main straight at SMSP I'm bouncing off 4th with a 8600RPM limiter. That shaft would be spinning at 8600RPM for a few seconds before I need to smash the brakes, by T2 it's getting close to that speed again. Now a drag car/roll race car would see that shaft speed for a 1 to 2 secs then they would coast, hit the brakes and that's it.
    • With same diff ratio, tyre diameter and road speed, the tailshaft rpm is the same regardless of the gearbag's ratio. Given that very quick drag cars are probably doing similar road speeds to the fastest circuit cars (circa 300 km/h), and there will be many of either category that can't go that fast and so you'd have inummerable matchups between drag and circuit car speeds at smaller numbers, and given that they are probably using rather similar tyre diameters and probably using similar diff ratios, and...where any of those numbers were different they could quite easily be in opposite directions thus cancelling out.... I think you'd find that there'd be more similarity than difference in tailshaft speed between these two use cases, no?
    • they might see those prop shaft speeds for 1 to 2 secs only
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
