Power for a lightly modded RB20det
Guest Simon-MrRx7
Im looking at transplanting an RB20det into a different car.
What sort of power at the wheels in KW's would i be making with a 3 inch exhaust with no cat, mandrewl bent, a decent front m,ount IC and stock turbo running 1 bar boost.
ECU, injectors, etc etc will all be stock appart from the fuel pump which will be a 600 Hp item with upped fuel pressure.
https://www.sau.com.au/forums/topic/1641-power-for-a-lightly-modded-rb20det/
I've got all of those mods.
I made 156rwkw with boost drop down to 12psi up top.
I've been told that if I slap a stronger wastegate spring in and hold 14psi all the way to the top I will make 170rwkw.
Max the timing out as I have at around 25deg which it can take a little more but to be on the safe side i havn't, will pick up around an extra 5rwkw as I found out.
Before the timing was advanced this much it made 152rwkw on approx 12psi.
Meggala... I had a run with andy's Stock R33 GTR he did a 5000rpm launch and i did a 4200rpm launch.
I seemed to launch better ?!?! only slightly as his nose was at my drivers door. I think I had 2 of those lucky fluky launches. :D
I stayed just in front all the way until half way through 4th roughly where we backed off :mad:
heheh lol Bragging rights.. I'm happy.. :)
He's getting an exhaust soon so i will not be happy then.. :D
Might have to get the HD wastegate spring.. see if that helps me sit there with his new exhaust. :) :shake:
Andy was Very surprised I must say.
Since the FMIC, I have to launch at 4000rpm otherwise it bogs down and If i don't launch it with load on the tyres and let the rev's raise with my foot down then boost kicks it wheel spins lots and causes a short shift to second then you have to play catchup.
Holy **** Joel how do you get traction with a 4200rpm launch on the street? I'm impressed, if I try to launch @ those rev's all I get right through to the end of 2nd or into 3rd is :burnout: Better quality rear rubber would help though!
I guess you are a launch, "master", considering the amount of practice you do :D :uh-huh:
It maybe because I have Std Suspension???
Even cheap tyres that have a soft sidewall?
And the tyres run lower than std pressure to get good wear otherwise it will chew out in middle.
I know that I don't use full throttle in first I basically try to get to 7000rpm with a slow throttle feed.
Its very much like launching my old cortina 4speed that didn't have lsd.
I probably get to 1/2-3/4 throttle in 1st max.
hehe It was a grippy road surface but.. :D
I'm starting to get to know the look of grippy and non grippy.
    • Just buy a BMW if you want that... You can then choose whatever engine of theirs you want 😛
    • Clear vinyl wrap or clear coat?
    • There really needs to be an ODBII item that can play intake noise through speakers, synchronized with your current RPM and TPS%.
    • Worth most of the $50k alone!
    • So, we now have a straight and clean boot lid inbound and the car goes in for paint, again, on Wednesday, and will be ready on Friday, all ready to get cams and stuff on Monday  And by straight and clean.....I mean a brand new OEM one that cost..... $1300....😪 Sadly there's no clean undamaged used soft top version available, plenty for the power retractable hard top versions though, which is arse and makes Mark have the sads I could have waited longer, until a NC sort top boot lid eventually turned up, but I'm sick of waiting and said fark it and made it rain cash, meh In other naturally aspirated news, one of the guys at work brought in his old Corola which had a 4AGE in it, really nice clean car with lots of mods, including ITB's, man that things induction noise sounds sick with all of the dorts that makes you smile......maybe the NC needs ITB's, yeah, basically for the noise they make, but they're pretty expensive, but, they sound so damn good I may bring this up when I drop the car up on Monday, and by may, I mean I will🤣🤑🤪🤣
