95' NISSAN SKYLINE R33 GTR
APPROX 100,000kms (Aftermarket Dash with 22,000kms)
RUNS FACTORY COMPUTER AND MAKES 280hp AT ALL FOUR WHEELS WITH 790Nm OF TORQUE (HAVE DYNO SHEET)
R34 NUR SPEC BALL BEARING TURBOS
AFTERMARKET CAMS
SPLITFIRE COIL PACKS
HKS COILOVER SUSPENSION
18" X 10" GOLD BBS WHEELS WITH NEW TYRES - 265 Front / 275 Rear
SLOTTED BREMBO BRAKES WITH AIR DUCTS AND AIR GUIDES (NEW BRAKE PADS)
FRONT MOUNT INTERCOOLER
JASMA EXHAUST
HEAVY DUTY BUTTON CLUTCH
NISMO REAR SUSPENSION ARMS
HKS EVC ELECTRONIC DUAL STAGE BOOST CONTROLLER
NISMO 320km WHITE DASH CLUSTER
NISMO TRIPLE GUAGE CLUSTER
GREDDY WATER TEMP GUAGE
GREDDY BOOST GUAGE
GREDDY OIL TEMP GUAGE
GREDDY OIL PRESSURE GUAGE
OIL COOLER
NISMO CLEAR SIDE INDICATORS
HKS POD FILTERS
FRONT STRUT BRACE
REAR STRUT BRACE
POLISHED OIL CATCH CAN
$29,990 O.N.O.
0400696678
VERY GOOD CONDITION. BUYER WILL NOT BE DISSAPOINTED.
Edited by BIGPSI
https://www.sau.com.au/forums/topic/164115-95-r33-gtr-with-mods/
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
