Hey Guys,
Anyone know if Kutsie can tune a Power FC D - Jetro in my 32 GTR ?
Anyone down here used one of these in their cars yet?
I am keen to get rid of my Airflows and hunt some more power
I don't wanna take my car to melbourne just for a tune :)
All help much appreciated
Thanks
Robert
https://www.sau.com.au/forums/topic/164128-pfc-d-jetro/
why not use AFM's? The D-Jetro isn't the best MAP sensor ECU out there (s**t to tune), if you realy want to go to a MAP sensor, i'd get an Autronic, or Haltec, and at that stage you've spent more than a PFC + bigger AFM's.
https://www.sau.com.au/forums/topic/164128-pfc-d-jetro/#findComment-3047170
thanks guys everyone has said the same thing thanks very much for the imput! just thought it would be the way to go as more flow less restriction and less electronics to stuff up
Anyone have any ideas how much it costs to tune when first bought, with bigger injectors and adjustable cam gears, just so i have an idea how much to budget?
https://www.sau.com.au/forums/topic/164128-pfc-d-jetro/#findComment-3049958
Roughly ~$150 an hour as an idea.
If you are serious about Nick tuning your car PM me.
https://www.sau.com.au/forums/topic/164128-pfc-d-jetro/#findComment-3053665
Well yet to order the computer will be doing it over the next two weeks after the coilovers go in,
I was under the impression the Airflow meters are going to be an ongoing problem with aftermarket turbo's and high boost levels and as everyone is aware they are not the kinda thing you wanna be replacing on a 6 monthly basis
Maybe X - Rated should shed some light on how long this kind of thing lasts on a large power basis, did you or Sav Man ever have to replace these after buying new ones and running for a whilst with a PFC?
Has anyone had a Haltec or Autronic ECU installed down here with success?
I would hate to be the first one to be bitten in the arse just by trying something new!
Have priced a Wolf V500 ($2350) err to expensive compared to what other companys are offering for lower prices
https://www.sau.com.au/forums/topic/164128-pfc-d-jetro/#findComment-3053732
I have had my Nismo AFM's for 2 years now, not 1 problems. one of my std AFM's died just after I got the car (due to age) that's why i went Nismo's. Our Targa car has 318rwkw, and has been raced all it's life, and it still has it's standard AFM's (and it runs a PFC), you just have to make sure your air filters are doing there job (and not over oiling them), and AFM's last for ages.
https://www.sau.com.au/forums/topic/164128-pfc-d-jetro/#findComment-3068977
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
