1x Genuine Momo boss kit.
Was on a non hicas S13. These also fit cerfios, it may fit skylines, Laurels ect.. Ive seen a gtst wheel in an S13, so in theory it will - This is for the buyer to check as hicas and non hicas boss kits maybe different.
You get everything thats in the photo.
$50 PLUS postage from the Sunshine Coast.
[email protected]
https://www.sau.com.au/forums/topic/164160-boss-kit/
Any idea if this will fit a '94 R33 GTS? Looks the same.
[email protected]
https://www.sau.com.au/forums/topic/164160-boss-kit/#findComment-3044858
