Apexi PowerFC ?
My muffler was fully customised to suit the car. He mailed me the end caps, I marked up the pipe locations (4 pipes in a single muffler) and he sent it back all welded. Certainly more expensive than a mass produced generic size, but that's hardly surprising. My R32 Exhaust has a Magnaflow muffler in it, if I need generic mufflers then they're usually a safe bet. I've got the Vibrant clamps on the intercooler pipes, just because they're nicer to use than the bolt together ones and not as expensive as a real Wiggins clamp.
Yeah. Nah. A grain of sand will take out a ceramic turbine that is doing 100000rpm.
Yes, it was checked with the roller rockers installed using a LS7 lifter that had been converted to a solid lifter with a dummy spring at 0 lash with a stock length pushrod. With the Johnson lifters longer pushrods were needed which are now 7.700" and 110 wall. Long thiccbois. People much more knowledgeable than I am are doing the measuring!
Well... New things have arrived... And now I need to really dig into the design of the power steering reservoir.
Interesting. I had that issue on my old car. After a rocker arm broke, the electrode must have been hit or something, though the cylinder didn't look like it was damaged when I put a scope down there, might have been the turbine but hard to imagine that a small piece of metal damage the turbine by that much. Seems like it's not even big enough to do the damage most of it.
