Don't care what they look like - as long as they are buckle free and can be balanced.
Don't are if they have rubber or not as I will be putting MT ET streets on them.
Must be fairly cheap !
https://www.sau.com.au/forums/topic/164190-wtb-cheap-wheels-for-drags-x2/
have a set of supra stockies - 17 x 9.5J 5 stud PCD114.3
suspect the offset is around +45.
used to house 255/40's which have gone to god.
can courier these to wherever it is that you are for $350 ( wheels and freight total).
B-Man - some members seem to be getting confused as to what you'll pay. I'm not so much confused as curious - but wouldn't ya help us all out by telling us what you will pay, as opposed to what you will not pay? Saves an awful lot of junk posts which are destined to go nowhere, and only bump this thread unreasonably ( in much the same way as I am doing, but hopefully SAU-wide posts like this are acceptable).
For what it is worth, I have a set of 4 Technocast rims ( don't have photos) that came off my GZ TT aero. They are 16's, and I suspect between 8.5 - 9.5. All in excellent condition ( not that that matters given your application for these rims), and I can courier a pair of these to your door for $250.
May also have some spare 17" Manaray RS-6 Hypers ( nice wheels) - have a full set but one is buckled, could do these for $320 for the whole set to your door.
Cheers,
J
Hi - It's a bit hard to say what I will pay - because it depends on the what people have to offer. I think I have posted a reasonable accurate description of what I want and why I want them.
Again for the record what I want is:
A set of two (2) - Rims for drag use
Any condition as long as they are not buckled and can be balanced. (ie Not new rims - scratched is Ok - I don't care what they look like - ie they can be 3,4,5 spoke, mesh, steel, dish - whatever.
at least 8" wide - prefer 9"
16" or 17"
between 30-40 offset
114.5 x 5 PCD (skyline, ford, mazda PCD)
Reasobably cheap
Prefer Sydney Pickup
Obviously less then $350 as I have stated this.
J - the Technocast (I don't know what this is) ones sound OK - if you could get details (size, etc and perhaps pics) that would be great. I don't need 4 so I amy be able to sell the other 2
Thanks
probably wont be interest but hey.
got 1 zeit rim 18" x 9 1/2" with a buckle off a toyota supra.
3 X 17” burnout tyres
1 x Bridgestone 215/45 ZR17 GRID II Runflat tyre with light surface bubling on inside. And a not penetrated cut. Tred – Deepest part has 5.5 mm, lowest part 3 mm evenly worn.
1 X Bridgestone Potenza RE 030 235/ 45 R17 light cuts but no deep ones. Tred deepest part – 4mm lowest part 2mm evenly worn
1 x ZEXIUS 225/50 R 17 with a small not penetrated cut, Worn slightly on angle. Left – 4mm, Middle – 3 mm, Right – 2mm
$40 the lot i am in gympie qld.
mark
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
