Don't care what they look like - as long as they are buckle free and can be balanced.
Don't are if they have rubber or not as I will be putting MT ET streets on them.
Must be fairly cheap !
https://www.sau.com.au/forums/topic/164190-wtb-cheap-wheels-for-drags-x2/
have a set of supra stockies - 17 x 9.5J 5 stud PCD114.3
suspect the offset is around +45.
used to house 255/40's which have gone to god.
can courier these to wherever it is that you are for $350 ( wheels and freight total).
B-Man - some members seem to be getting confused as to what you'll pay. I'm not so much confused as curious - but wouldn't ya help us all out by telling us what you will pay, as opposed to what you will not pay? Saves an awful lot of junk posts which are destined to go nowhere, and only bump this thread unreasonably ( in much the same way as I am doing, but hopefully SAU-wide posts like this are acceptable).
For what it is worth, I have a set of 4 Technocast rims ( don't have photos) that came off my GZ TT aero. They are 16's, and I suspect between 8.5 - 9.5. All in excellent condition ( not that that matters given your application for these rims), and I can courier a pair of these to your door for $250.
May also have some spare 17" Manaray RS-6 Hypers ( nice wheels) - have a full set but one is buckled, could do these for $320 for the whole set to your door.
Cheers,
J
Hi - It's a bit hard to say what I will pay - because it depends on the what people have to offer. I think I have posted a reasonable accurate description of what I want and why I want them.
Again for the record what I want is:
A set of two (2) - Rims for drag use
Any condition as long as they are not buckled and can be balanced. (ie Not new rims - scratched is Ok - I don't care what they look like - ie they can be 3,4,5 spoke, mesh, steel, dish - whatever.
at least 8" wide - prefer 9"
16" or 17"
between 30-40 offset
114.5 x 5 PCD (skyline, ford, mazda PCD)
Reasobably cheap
Prefer Sydney Pickup
Obviously less then $350 as I have stated this.
J - the Technocast (I don't know what this is) ones sound OK - if you could get details (size, etc and perhaps pics) that would be great. I don't need 4 so I amy be able to sell the other 2
Thanks
probably wont be interest but hey.
got 1 zeit rim 18" x 9 1/2" with a buckle off a toyota supra.
3 X 17” burnout tyres
1 x Bridgestone 215/45 ZR17 GRID II Runflat tyre with light surface bubling on inside. And a not penetrated cut. Tred – Deepest part has 5.5 mm, lowest part 3 mm evenly worn.
1 X Bridgestone Potenza RE 030 235/ 45 R17 light cuts but no deep ones. Tred deepest part – 4mm lowest part 2mm evenly worn
1 x ZEXIUS 225/50 R 17 with a small not penetrated cut, Worn slightly on angle. Left – 4mm, Middle – 3 mm, Right – 2mm
$40 the lot i am in gympie qld.
mark
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
