Guys have my R34 Side mount cooler for sale, its in excellent condition, reason for selling is im puting a fount mount in, this would be a good upgrade for a RB20 or VL turbo.
also a stock cooler for a R33 dont know if there is any difference in 33 and 34 but its from olf 33 its in great condition
Also have the following
Stock turbo back exhaust for a R34GTT in exellent condition
1 x Stock BOV R33
1 x Stock BOV R34
A genuine head unit from my 33 which in cludes headunit, 12 stacker, and 4.5 inch tv all from my 33 which i believe is in working condition, i never got it to work as it wasnt plugged in
That all
Make an offer guys, just want it gone
Cheers
Matt
https://www.sau.com.au/forums/topic/164197-fs-r34-r33-gtst-bits/
do you have a pic for this tv..
what brand is it
how much you want for it
i dont have a pic but its a genunie nissan item
what erver u offer man 150 wit hthe stacker and everything
make an ofer dude 150 i guess pm me an offer a reasonalbe one.
I dont have pics but its in excellent condition
Also have the 32 GTR rims for sale with 90% rubber for sale in another thread
650
bump it up
ok guys i have now off the car
standard full system exhaust will sell seperate if needed
R33/34 BOV
R34 GTT Side mount cooler
4 near new R32 rims with rubber in excellent condition
headunit with tv still available
R33 side mount cooler
Cheers
all open to offers
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
