Hi guys,
Just added an s-afc and a HKS EVC 3 to the car, and it dyno'ed at 255hp with 200rwkw at 13psi (did 270hp at 15psi)
my mods include:
hi-flowed T03 with T04 compressor
full turbo back exhaust
s-afc
EVC 3 boost controller
stock intercooler
I'm wondering whether or not this is the power it SHOULD be making or whether it is lacking anything.
And what would be a good quartermile time for a car like this
All input will be greatly appreciated
Zak
the car is a 1995 R33 Gts-t
https://www.sau.com.au/forums/topic/16422-is-this-good-power-or-not/
hmmmm.. does look you're not pushing much more than the standard 180-200rwkw most stock turbo people can get.
everything must be running pretty hot, thats all i can say! What has your tuner told you in terms of why you aren't getting more?? I am sure the first thing he *must* have said was the i/c.. even a cheapish GTR cooler should give u large gains.
Well I've never seen the stock turbo make 200rwkw with the standard intercooler, so there's definately more power to be had, I imagine another 30rwkw would be on the cards with a FMIC.
1/4 mile times for your current setup should be mid-low 13's, with the FMIC you can certainly crack a high 12 if you can get the power to the ground, I've noticed alot of peoples times don't drop much with the increase of power but the mph do go up indicating not much traction, so in my opinion any thing over 230rwkw must have slicks to race with or your just wasting your time.
Originally posted by Nrage33
and it dyno'ed at 255hp with 200rwkw at 13psi (did 270hp at 15psi.
Not being picky (just filling in time)
255hp = 190rwkw @ 13psi
270hp = 201rwkw @ 15psi
correct ?
:bahaha:
I'd personally be U/G'ing the stock IC @ ~170rwkw.
yea i know I should be replacing the stock cooler...haven't had the funds for that kinda work yet. I've got one on hold, $1500 for cooler plus piping...good price or not? any better deals?
I don't run it at 13psi all the time, 9psi is good enough for the streets. Can't afford to go nuts around here anymore
I was told by several ppl the car could make into the high 12's if the launch is a great one.
benm u're right about the numbers...my mistake
Originally posted by BOOSTD
Mine made an extra 20+rwkw just buy changing the cooler and nothing else.
How can an i/c increase power... doesn't it just allow for longer lasting power by keeping things cool?
So by adding fmic to a line that already has exhaust and filter, will see increase in power?
FMIC with the usuall mods of more boost, exhaust, filter etc... won't yield great results without the introduction of at least an SAFC or full replacement ECU, as those mods generally see the A/F ratio run deep into the 10:1's, but once the A/F is returned to a respectable 12:1 that's when the results come.
With FMIC, exh, stock turbo my car made 168rwkw, with the SAFC tuned at 11.8:1 it made 188rwkw@12psi, only 20kw more in peak power but power was up all through the rev range and the greatest gain was at 5500rpm where it made 44kw more.
All you guys are forgetting about flow. There is power to be had if you increase flow. This is the main restriction with the stock cooler. You will make more power at the same boost level and temp with a larger better flowing core. Try testing your boost level first before your stock cooler and then after and you`ll understand. No flow-no power no matter what the temp.
Guest INASNT
My tuner has told me everything is running fine, tuned it all the way up to 18psi at one point. He's assured me that the stock cooler is fine, but has obviously recommended a front mount :P
does your tuner realise that there is around 7 or more psi pressure drop through the stock cooler? and with a bigger turbo flowing more air it would be even worse!
I'd suggest an upgrade of the cooler and the computer. I've always been of the opinion that if you change the turbo, you change the computer (and a SAFC isn't really a full computer change imo). There's a lot of power to be had in adjusting the timing I think.
2 other things, my car became a lot more powerful with just a cooler change, so I really recommend it. Also, I feel 14psi is fine as a constant setting for the street because you aren't holding it at that like you are on the track.
BOOSTD, sorry that post wasnt very clear was it.
I was just suggesting that with a stock cooler on stock turbo, it is inadvisable to wind boost past about 12psi because of the pressure drop on the stock cooler - as you pointed out. With a stock turbo on FMIC, you can only get another 2.5 psi, because after that the resistance generated by the compressor causes alot of strain on the ceramic turbine, and failure is a matter of time - so the net total boost increase (flow gain) is only a couple of psi - safely. Definately a couple of psi worth having though.
As boost pressure is measured from the plenum, the boost seen by the engine is still going to be the same with bigger cooler, it will just be cooler, denser charge. (unless you wind the boost up)
I do understand that you were pointing at the huge pressure drop on the stock cooler above 6000prm:)
the above figures do not allow for the BOOSTD 'give it 1.1bar till she blows' theory...lol
does that make more sense?
    • Be more active mate.. , not taking the piss ❤️, your long term health will love you for it I would think something like a kettle bell or 2 laying around in areas you go past during the day would be awesome for ADHD.... "Oh look, a kettlebell", and exercise helps your brain health as well My mates son was a bit of a problem child, diagnosed wirh ADHD, and some other things that had his brain occasionally doing loops, until we got him into a training program, the difference after he started training was amazing, he had more focus, and his fitness levels exploded, it is like he is a totally different kid to be around Brain chemistry something something Stay fit stay strong mate
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
