replacement box filter
Guest Boxhead
im pretty sure you can get a nismo one, or possibly a HKS one, but i am not sure who you would approach about getting one...
and i rekon if you cant find a k&n fit in replacement your not looking hard enough, ive heard of lots of people using one...
but those things aside, im pretty sure rev210 is using a drop in replacement, ask him.
Is that size 282mm X 169mm ?
Same as N14 Pulsar and 200SX ?
If so I have 100 Jamex ones that I sold about 3 years ago and the guy went bust, so I repossed them. They are triple density foam, the ducks guts in airfilters.
If not let me know the size and I might have some.
If they fit, $35 each posted to anywhere in Australia, I'll take Visa or Mastercard.
Is there a NOTICABLE change in power when the filter is changed for a highflow drop in replacement? We pulled out the filter in the R33 for a test run down the road and noticed a fairly lage gain in power. (for test purposes only, we put back in straight away).
Would a good panel filter show almost as high of a gain as a boxed pod or no filter? It's hard to decide on what option is best as they both have their good and bad points.
Hi guys, 360's, so the Jamex ones will fit. We get a 6 rwkw increase on mild tune 200SX's with them, don't see any reason why you would not get around the same on a GTST.
They retail for $90 each so $35 posted is a bargain. Let me know if you want any. I will post a For Sale in the relevant place.
Guest silver33 guy
i was gonna go a pod filter originally but have been warned about the noise level. i like my skyline to keep a low profile - the huge exhaust already draws a few looks from the cops! if i don't get a performance gain i can 'feel' with the k&n, i may still switch to a pod filter.
oh so we are talking about panel filters here? of course there are drop in panel filters for skylines... k&n, blitz, hks, trust, apexi, redline... every brand has them. You can get the k&n or redline from Autobarn, or the other Jap stuff from performance shops... this shouldn't be an issue at all!
the challenge is trying to find a air box containing a pod filter like mugen do for hondas... they would work wonders, keeping out engine heat and saving you from a canary (provided cops don't open up ya box)
Hang on, let me get this this right............
In Vic your'e not allowed to change your air filter?
How do they know that the car wasn't complied with it?
Why do they think it's illegal?
Surely not too loud?
It's not a pollution issue, the air goes in, not out doesn't it?
Or is this just an excuse to give you guys a hard time?
If it is, someone should sue, find a car that's complied with a POD, cop a couple of defects, then sue them for harrasment. Win just one case and they will have to stop this sort of crap.
How does anyone know whether it is complied with the pod or not, the import papers don't show such detail... could have put it on afterwards... true air goes in, but more air comes out (that's what i heard). I also heard cos it could catch on fire in the engine bay, and i heard they like to give us a hard time.
Guest RedLineGTR
I know people that have been given fines and yellow stickers for even boxed pods, and epa usally open up the box to see if there is a filter or a pod (For r32 you can mod the box to house a pod) anways the best alternative would be a k&N panel filter, they have been proven to filter the air quite well compaired to other filters (also foam ones) they are easy to clean and last for ages. The price isnt to bad either. My 2 cents.
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
