replacement box filter
Guest Boxhead
im pretty sure you can get a nismo one, or possibly a HKS one, but i am not sure who you would approach about getting one...
and i rekon if you cant find a k&n fit in replacement your not looking hard enough, ive heard of lots of people using one...
but those things aside, im pretty sure rev210 is using a drop in replacement, ask him.
Is that size 282mm X 169mm ?
Same as N14 Pulsar and 200SX ?
If so I have 100 Jamex ones that I sold about 3 years ago and the guy went bust, so I repossed them. They are triple density foam, the ducks guts in airfilters.
If not let me know the size and I might have some.
If they fit, $35 each posted to anywhere in Australia, I'll take Visa or Mastercard.
Is there a NOTICABLE change in power when the filter is changed for a highflow drop in replacement? We pulled out the filter in the R33 for a test run down the road and noticed a fairly lage gain in power. (for test purposes only, we put back in straight away).
Would a good panel filter show almost as high of a gain as a boxed pod or no filter? It's hard to decide on what option is best as they both have their good and bad points.
Hi guys, 360's, so the Jamex ones will fit. We get a 6 rwkw increase on mild tune 200SX's with them, don't see any reason why you would not get around the same on a GTST.
They retail for $90 each so $35 posted is a bargain. Let me know if you want any. I will post a For Sale in the relevant place.
Guest silver33 guy
i was gonna go a pod filter originally but have been warned about the noise level. i like my skyline to keep a low profile - the huge exhaust already draws a few looks from the cops! if i don't get a performance gain i can 'feel' with the k&n, i may still switch to a pod filter.
oh so we are talking about panel filters here? of course there are drop in panel filters for skylines... k&n, blitz, hks, trust, apexi, redline... every brand has them. You can get the k&n or redline from Autobarn, or the other Jap stuff from performance shops... this shouldn't be an issue at all!
the challenge is trying to find a air box containing a pod filter like mugen do for hondas... they would work wonders, keeping out engine heat and saving you from a canary (provided cops don't open up ya box)
Hang on, let me get this this right............
In Vic your'e not allowed to change your air filter?
How do they know that the car wasn't complied with it?
Why do they think it's illegal?
Surely not too loud?
It's not a pollution issue, the air goes in, not out doesn't it?
Or is this just an excuse to give you guys a hard time?
If it is, someone should sue, find a car that's complied with a POD, cop a couple of defects, then sue them for harrasment. Win just one case and they will have to stop this sort of crap.
How does anyone know whether it is complied with the pod or not, the import papers don't show such detail... could have put it on afterwards... true air goes in, but more air comes out (that's what i heard). I also heard cos it could catch on fire in the engine bay, and i heard they like to give us a hard time.
Guest RedLineGTR
I know people that have been given fines and yellow stickers for even boxed pods, and epa usally open up the box to see if there is a filter or a pod (For r32 you can mod the box to house a pod) anways the best alternative would be a k&N panel filter, they have been proven to filter the air quite well compaired to other filters (also foam ones) they are easy to clean and last for ages. The price isnt to bad either. My 2 cents.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
