replacement box filter
I have a K & N Filter in my R33 and as mentioned it is the same as the VN-VS Commodore one. The product code to look for is 33-2031-2.
I replaced my HKS pod for the stock airbox and K & N panel, and I find it just as good if not better as I never had a CAI and was sucking in hot air.
Daniel
Guest silver33 guy
i've never read anywhere that it is illegal to have a pod filter in victoria. all i read was that it is illegal to have more than 1 mod done to the air intake ie. pod filter and BOV.
true i have heard of the EPA stopping people if it is too loud but if the noise is contained, it is legal, right?
and finally, BOVs are a legal item aren't they?
Guest silver33 guy
Got my replacement drop in fiter. Like Daniel said, it is the K&N 33-2031-2. Fits perfectly. Autobarn has it on special currently for $109 (normally $129).
Haven't noticed much of a performance gain...yet. Probably should let the ECU adjust to the extra air over the next 2 days before I comment. It's definitely running smoother and making a sweet noise when under boost though.
Thanks to all for your feedback.
    • Do the following first and get back to us. - Clean and verify your IACV - Verify for vacuum leaks/post MAF leaks. (Pressure test is the best and cheapest way) - Do you have a BOV with stock ecu/MAF? If so, remove it.
    • Hey all, The skyline I have is stalling when the engine is at normal operating temp.  When starting it while it is cold, it'll run just fine.  I have replaced the battery (bad cell), I have replaced the fuel pump, fuel filter and clean the MAF sensor.  Any other suggestions?
    • Thanks for all the information on this.  I tried ordering the parts from Amayama website and all 3 Solenoids are discontinued and not available.  Does anyone have any other websites to suggest that I could find the parts?   Separate issue-- I will start a new thread, but basically the vehicle is stalling when warmed up.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
