  • Replies 43
might be worth checking the injector if in doubt switch it with another cylinder. Comp test it and see what happens!
yeah im hoping it might be injector or injector solders or something
but gotta drive it home! cant leave it in the work car park over night!
but of a thud thud clank coming from under the car but thinking its the exhaust hitting stuff because its running so rough
https://www.sau.com.au/forums/topic/164278-ohh-nooooo/#findComment-3045332
hey ed sorry for the simple q, but what are the signs that the engine has dropped a cylinder? would it be similar to an engine missing?
oh yeah.. got the coilpacks tues and went back to the old plugs and worked a charm, fixed my missfire.
https://www.sau.com.au/forums/topic/164278-ohh-nooooo/#findComment-3045354
It does sound like shes dropped a cylinder, The only thing you can do is comp test it and go from there really. Its not like an injector to just give way like that but it can happen.
If you have changed the plugs and switched coils etc its not lookin good. If you need help sourcing another engine or getting it fixed let me know. Got enough RB20 crap laying around to get it running again!
https://www.sau.com.au/forums/topic/164278-ohh-nooooo/#findComment-3045364
i did the injector wiring myself so ill give it a wiggle and see if it comes back to life, but im pretty sure i have dropped a cyl....
ill buy a comp tester from supercheap tonight and bring it back to work to test it...
reckon its safe to drive home through the cross city tunnel or will i just do more damage?
desperate for any help anyone can give!
https://www.sau.com.au/forums/topic/164278-ohh-nooooo/#findComment-3045369
wet and dry? dont i get some guage thing that i screw into the sparky hole and see what psi its got?
its just a 5min drive so hopefully she gets there!
i guess if it was something bottom end like bearings or what not i would dropped more cyls?
i know alot about cars but nothing about engine blow ups! never experienced one before
https://www.sau.com.au/forums/topic/164278-ohh-nooooo/#findComment-3045402
compression test it first.
stick a rag on the end of a screw driver and put it inside the spark plug hole, if it comes out clean then you're safe. if its got oil in it its time for a rebuild.
or just check the spark plug for oily shit all over it.
https://www.sau.com.au/forums/topic/164278-ohh-nooooo/#findComment-3045413
ok guys
bought a tester tonight, tested cyls 1 and 5 (problem cyl is 5) did a dry test i think its called and both read 150psi! thats a good thing isnt it! i still need to do a wet test...
checked spark yes, sparkies ok
im 65% leaning towards one of the injectors playing up, OR one of the injector resistors having a melt down seeing as it happened so fast...
the car is at work at the moment, can leave it there most of the weekend, so ill order the $25 resistors and go in with a multi meter and do the wet test...
phew glad she can hold some pressure!
https://www.sau.com.au/forums/topic/164278-ohh-nooooo/#findComment-3046121
I know someone not too far from you who can check your engine well and truly. All your cylinders will have the same comp readings, guaranteed...
...but the insides might look a bit mangled. His name starts with an 'H' and rhymes with 'vermin' :pwned:
Seriously though, hopefully it all turns out ok mate.
https://www.sau.com.au/forums/topic/164278-ohh-nooooo/#findComment-3046155
how long have you been drinking for hahahahahaahahhah i totally didnt get that!!!
wont have much time to do the car tomorrow so saturday it is, just ordered new resistors so ive got a backup!
damn cars!
https://www.sau.com.au/forums/topic/164278-ohh-nooooo/#findComment-3046160
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
    • How will O2 sensor voltages help to identify it when it is sputtering?
    • What do LTFTs look like? What do MAF voltages look like? O2 sensor voltages/AFRs? Knowing O2 voltages especially when it sputters would help a lot.
