  • Replies 43
might be worth checking the injector if in doubt switch it with another cylinder. Comp test it and see what happens!
yeah im hoping it might be injector or injector solders or something
but gotta drive it home! cant leave it in the work car park over night!
but of a thud thud clank coming from under the car but thinking its the exhaust hitting stuff because its running so rough
https://www.sau.com.au/forums/topic/164278-ohh-nooooo/#findComment-3045332
hey ed sorry for the simple q, but what are the signs that the engine has dropped a cylinder? would it be similar to an engine missing?
oh yeah.. got the coilpacks tues and went back to the old plugs and worked a charm, fixed my missfire.
https://www.sau.com.au/forums/topic/164278-ohh-nooooo/#findComment-3045354
It does sound like shes dropped a cylinder, The only thing you can do is comp test it and go from there really. Its not like an injector to just give way like that but it can happen.
If you have changed the plugs and switched coils etc its not lookin good. If you need help sourcing another engine or getting it fixed let me know. Got enough RB20 crap laying around to get it running again!
https://www.sau.com.au/forums/topic/164278-ohh-nooooo/#findComment-3045364
i did the injector wiring myself so ill give it a wiggle and see if it comes back to life, but im pretty sure i have dropped a cyl....
ill buy a comp tester from supercheap tonight and bring it back to work to test it...
reckon its safe to drive home through the cross city tunnel or will i just do more damage?
desperate for any help anyone can give!
https://www.sau.com.au/forums/topic/164278-ohh-nooooo/#findComment-3045369
wet and dry? dont i get some guage thing that i screw into the sparky hole and see what psi its got?
its just a 5min drive so hopefully she gets there!
i guess if it was something bottom end like bearings or what not i would dropped more cyls?
i know alot about cars but nothing about engine blow ups! never experienced one before
https://www.sau.com.au/forums/topic/164278-ohh-nooooo/#findComment-3045402
compression test it first.
stick a rag on the end of a screw driver and put it inside the spark plug hole, if it comes out clean then you're safe. if its got oil in it its time for a rebuild.
or just check the spark plug for oily shit all over it.
https://www.sau.com.au/forums/topic/164278-ohh-nooooo/#findComment-3045413
ok guys
bought a tester tonight, tested cyls 1 and 5 (problem cyl is 5) did a dry test i think its called and both read 150psi! thats a good thing isnt it! i still need to do a wet test...
checked spark yes, sparkies ok
im 65% leaning towards one of the injectors playing up, OR one of the injector resistors having a melt down seeing as it happened so fast...
the car is at work at the moment, can leave it there most of the weekend, so ill order the $25 resistors and go in with a multi meter and do the wet test...
phew glad she can hold some pressure!
https://www.sau.com.au/forums/topic/164278-ohh-nooooo/#findComment-3046121
I know someone not too far from you who can check your engine well and truly. All your cylinders will have the same comp readings, guaranteed...
...but the insides might look a bit mangled. His name starts with an 'H' and rhymes with 'vermin' :pwned:
Seriously though, hopefully it all turns out ok mate.
https://www.sau.com.au/forums/topic/164278-ohh-nooooo/#findComment-3046155
how long have you been drinking for hahahahahaahahhah i totally didnt get that!!!
wont have much time to do the car tomorrow so saturday it is, just ordered new resistors so ive got a backup!
damn cars!
https://www.sau.com.au/forums/topic/164278-ohh-nooooo/#findComment-3046160
    • Well, in the same way that you can't tell any SUV from any manufacturer in any size category from any other one, "sports" coupes now all look identical. Stand back and squint your eyes and the Supra and the 400Z and the GR/BRZ things all look the same. I was just thinking last night, when sitting behind a Subaru CrossTrek, that I have no idea what it is, how it differs from an XV, or a Forester, or an Outback, or anything else Subaru offer, and I couldn't tell if it was supposed to be small, medium or large. I contrasted that to the good old days, where a HQ Kingswood had familial similarities to an LJ Torana, but there is no way that you could confuse them, and how a bit later, the HX Kinger and the concurrent Torana and the Gemini all had familial similarities, but you still could not confuse them. Ditto the ugly Fords and Chryslers of the era. But now, a RAV4 looks like a Kluger, looks like a Yaris/Cross/whatever they're calling those stupid f**king things, looks like every other Toyota that's not a Camry/Corolla sedan.
    • The Prelude doesn't look that bad without all that lens distortion in those pics. Makes it look disproportionate when it isn't. Actually I kind of liked it at the Osaka Auto Messe earlier this year.
    • Pour in the highest octane, non-ethanol fuel you can get and see if the readout changes. If it's dead bang on 11% then I would question the sensor. Another quick test, just take it out and run normal (in an american accent) gas-o-line through it and see if the sampled ethanol or lack of changes.   United E85 here in the land of drop bears does vary a bit, I've had as high as E87 (could be water in their tanks too, who knows)
    • Yep. And if you ever do, you'll just have to deal with it then.
    • E10 is pretty tightly regulated in percentage. Too much and engines can't adapt. Every incentive is against them to have too little ethanol though. The more ethanol the higher the octane.
