  • Replies 43
ive checked spark, took the coil pack out and earthed it on the engine through a screw driver (the professional way hahaha)
ill test the injector and resistor tomorrow when i can, im really leaning towards one of the injectors or resistors shitting themselves....
lol @ r31, really leaning towards a shitter to drive everytime my car dies!
Rb26 would be worth more than the car lol
ill get another rb20 and run 28psi lol
slide fly down and fix it for me, ill give you steaks..... :P
Ordered new resistors so should be coming today, cant fix it today so have to leave it here another night... lucky its safe! tomorrow is D day!
the injectors and resistors came in and out 6times, due to 68ohm resistors instead of 6.8 so i dont think that i woulda done a 110% job putting them in the last time! having the shits and all......
the loud clanging, metal noise was scaring the sheet out of me last night, but i figured out that since it was running so rough it was ossicilating down the exhaust and it was shaking on the mounts PHEW!
umm. have you got your range on the mutlti meter rioght? it sounds that its out by a factor of ten.
20 resister does all 6 (2wires). not individal like a rb26. whats the compression or all the cylinders. hows the sparkplugs, so its got spark on 5 and 1? if so its an injector or plug.
well bit of modding, rewiring and checking and she runs again..
even with the weird connection injector, which i want to get rid of asap...
Dave i sent you a PM about the 1 or 2 you have laying around?
Car atleast runs now, but drives like its had the shit thrashed out of it at a drift day by some hoon!!!!
New sparkies, oil and filters tomorrow! horray
still havent washed the mud off it hahaha
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
