  • Replies 43
ive checked spark, took the coil pack out and earthed it on the engine through a screw driver (the professional way hahaha)
ill test the injector and resistor tomorrow when i can, im really leaning towards one of the injectors or resistors shitting themselves....
lol @ r31, really leaning towards a shitter to drive everytime my car dies!
Rb26 would be worth more than the car lol
ill get another rb20 and run 28psi lol
slide fly down and fix it for me, ill give you steaks..... :P
Ordered new resistors so should be coming today, cant fix it today so have to leave it here another night... lucky its safe! tomorrow is D day!
the injectors and resistors came in and out 6times, due to 68ohm resistors instead of 6.8 so i dont think that i woulda done a 110% job putting them in the last time! having the shits and all......
the loud clanging, metal noise was scaring the sheet out of me last night, but i figured out that since it was running so rough it was ossicilating down the exhaust and it was shaking on the mounts PHEW!
umm. have you got your range on the mutlti meter rioght? it sounds that its out by a factor of ten.
20 resister does all 6 (2wires). not individal like a rb26. whats the compression or all the cylinders. hows the sparkplugs, so its got spark on 5 and 1? if so its an injector or plug.
well bit of modding, rewiring and checking and she runs again..
even with the weird connection injector, which i want to get rid of asap...
Dave i sent you a PM about the 1 or 2 you have laying around?
Car atleast runs now, but drives like its had the shit thrashed out of it at a drift day by some hoon!!!!
New sparkies, oil and filters tomorrow! horray
still havent washed the mud off it hahaha
    • If you get a 33 pump, bracket and harmonic balancer that will bolt straight up
    • Hey y'all, So i went to replace my outer tie rod end and it looks like my inner is cooked as well. Problem is, the inner tie rod's part no seems to be completely unique, it's not the same as in the other Skylines.  It's 48521-23U25. This is NOT the same as the GTTs or GTRs. If you look online, only place I can get them is Amayama (https://www.amayama.com/en/part/nissan/48521aa325), but given that the "quantity available" is listed as ">1," it worries me that lead time on this will be infinite. Wondering if any other ENR34 owners have found replacement inner tie rods that work and are readily available? Are tie rods not that deep and easy to interchange? I'm in the USA, so if anyone else has found em, LMK! Also - it looks like this part for the Leaf is the same number, except there's a 0 added right after the U. Does this mean anything of value or are they completely different parts? 48521-3U025 - Inner Tie Rod 2007-2014 Nissan | Nissan Parts & Accessories Online
    • There is no difference. The existing turbo and intercooler would very most likely not be suitable for reuse. The existing tune would be meaningless. The issues with fitting things in are exactly the same.
    • Here’s a follow up question, what if you add a super charger to an already turned engine like a rb25det or something. Would the systems in place (inter coolers and exhaust manifold) be a good way to lessen time and head ache? Or would it be more annoying to add a supercharger to the turbo-ed system then designing a new system entirely?
    • Curious if you've discussed this with them, maybe they can remove it for you since you requested it not to be coated.
