Defiantly worth the effort. Both wheels lock well under power. Can boost it rite up in tight corners and also both compression lock up under braking and the car remains straight. Feels much, much better then the 2-way LSD in the Passage. When it does let go in a power slide the control is incredible compared to before. A recomended mod for anyone.
Where are you located? Would you do the job for others as I don't have the appropriate tools and my car always one legs and pulls to one side. Obviously some moola will be given. Can post the internals so you don't have to take the entire diff.
Its a very time consuming process and time is something I don't have at the moment. Probably give me a month and PM me and it might be possible. Between this car and work there's nothing left. Sorry.:(
On another note I hit a realy tight corner yesterday going way too fast and got a chirp from the inside wheel so its defiantly working well.
Edited by Bauerpower
saved our ass here in the UAE =) doing it now.
fitted em up, what a bitch to get the center back into the car lol. when i finaly got it in, the splines on the longer half shaft didnt line up in the final section. what a bitch, back out with the center it came, i did actualy line up the splines like you said, might i add for anyone else doing this. once you put ur shims in put both half shafts into the center completly in, then tighten the 2 philips heads, then leave the shafts in. put ur ring gear over the top and rattle that up with the half shafts still in the center. makes it alot easier and no room for error. the first time i was literaly .2mm off the splines being 100percent. and yet it wouldnt go in all together.... peace!
  • 3 weeks later...
Any chance of getting the pics working again really want to give this a go. So say about 3mm would be good for drifting or should i go more like 3.4?
Pretty much depends how screwed your diff is, it'll basically either be almost completely locked or it'll skip around corners and open up under power (worst of both worlds), or it'll be the same.
So just go the biggest you can get in there if you want to lock it, if you want it to be like an LSD just get an LSD.
My local Nissan had them in stock.. did they say they were ex-east? or ex-japan?
3 weeks sounds about right from Japland, everything I've gotten that was ex-east gets sent in an overnight bag so I have it within a couple of days (case in point, ordered a brake booster 1-way valve on Saturday that was ex-east and it arrived yesterday).
  • 1 month later...
just got around to putting mine in,both sides have a shim or 2 with 3 in total so i've got more then 3.6+ mm in there nearing 4 id say (will need to double check invoice to confirm).
so question is how long does it take to bed/ wear in as in getting some shuddering under hard cornering ?
Edited by Dan_J
  • 4 weeks later...
Hello!
I have heard that you can´t shim up a GTST Diff for it´s a viscodiff and not a lsd diff, the shims may take all the power from the diff and the viscodifferential will break? That a shimmed diff will not work in the long run? Is this bullshit or true?
Many people seem very happy with their but boring if it would break!?
Victor
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
