What do u reckon of a Full Lock?? Too much on the street? n chop up my tyres easily? I'm thinking of doing this n ordering some shimms n rang nissan n said it will take 2 weeks ex Japan.. or i could get a full lock one for 300bux?? What u reckon?
Search for opionons on locked diff's, i have had one in my old rx7, very predictable and easy to manage, if its only a matter of waiting 2 weeks then i would wait, if its just a track car or a weekender then there is no reason not to lock it, if its a daily then i'd wait 2 weeks.
If you do search for other threads on locked diffs take note of the people who say that locked diffs are deadly blah blah blah, 95% have never had one, then note what people who have had them think of them!
Also how bad is your diff, i was all prepared to do this and my clutch in the one weekend, everything was set then found out i had to wait for shims, put some penrite limslip 85w-140 and now its all good.
Mine would single spin 10-20% of the time so it isnt totally shagged but enough to be annoying.
I wouldn't do it in a daily, mainly because of the destruction to tyres and bushes, also cops will hear/see it if they pull you into an rbt.
Just save for a 1.5 way, a second hand centre is only 500 usually, get the clutches machined and it all professionally installed would set you back maybe $1k max. Do it once do it properly.
i was planning to shim my diff also but all these ppl saying how it chirps and locks up on low speed/tight corners just puts me off.
do 1.5/2ways do this also?
if so then i will just stick with standard or whack in a GTR LSD.
1.5 ways and proper 2 ways don't. Kaaz and improperly shimmed LSDs will chirp and carry on.
I have no idea why people buy kaaz 2 ways that chirp etc, what is the point, might as well just get a locker if they are going to carry on and cause understeer.
Any1 else know where i can shimms besides Nissan n waiting 2 weeks? in Perth of course :D
The LSD feels a little bit loose.. in can feel it in full turn in low speeds like 1st gear.
Edited by Black_CSR
get them express from adelaide in 1 day?
im pretty sure unley nissan has had them that day whenever I've been there.
Express Adelaide?? u mean if they have to order it in the east like Adelaide?
No I mean that Unley Nissan here in Adelaide has always had diff shims in stock when me or a friend has purchased them, hence call them up, pay over the phone and get them to send them to you via an express post satchel so they arrive the next day.
Faster than 2 weeks from Japan and probably cheaper.
Black_CSR, which Nissan did you try?
I always go through Steve at Northside Nissan and I'm pretty sure Grifforelli got some from there last week.
I rang Total Nissan Cannington... Might call Northside then n try my luck.
Does any one have any negative on going to a ~4.6 shim, as in putting 2x 1.49 and leaving the standard .8's in there.?
Depends how worn the viscous unit is (if the shims have scored into it), a 1.49 each side was enough to lock my diff totally for a couple of weeks.
Bubba, has it ever single pegged since shimmed? Also does it still chirp around tight corners?
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
