What do u reckon of a Full Lock?? Too much on the street? n chop up my tyres easily? I'm thinking of doing this n ordering some shimms n rang nissan n said it will take 2 weeks ex Japan.. or i could get a full lock one for 300bux?? What u reckon?
Search for opionons on locked diff's, i have had one in my old rx7, very predictable and easy to manage, if its only a matter of waiting 2 weeks then i would wait, if its just a track car or a weekender then there is no reason not to lock it, if its a daily then i'd wait 2 weeks.
If you do search for other threads on locked diffs take note of the people who say that locked diffs are deadly blah blah blah, 95% have never had one, then note what people who have had them think of them!
Also how bad is your diff, i was all prepared to do this and my clutch in the one weekend, everything was set then found out i had to wait for shims, put some penrite limslip 85w-140 and now its all good.
Mine would single spin 10-20% of the time so it isnt totally shagged but enough to be annoying.
I wouldn't do it in a daily, mainly because of the destruction to tyres and bushes, also cops will hear/see it if they pull you into an rbt.
Just save for a 1.5 way, a second hand centre is only 500 usually, get the clutches machined and it all professionally installed would set you back maybe $1k max. Do it once do it properly.
i was planning to shim my diff also but all these ppl saying how it chirps and locks up on low speed/tight corners just puts me off.
do 1.5/2ways do this also?
if so then i will just stick with standard or whack in a GTR LSD.
1.5 ways and proper 2 ways don't. Kaaz and improperly shimmed LSDs will chirp and carry on.
I have no idea why people buy kaaz 2 ways that chirp etc, what is the point, might as well just get a locker if they are going to carry on and cause understeer.
Any1 else know where i can shimms besides Nissan n waiting 2 weeks? in Perth of course :D
The LSD feels a little bit loose.. in can feel it in full turn in low speeds like 1st gear.
Edited by Black_CSR
get them express from adelaide in 1 day?
im pretty sure unley nissan has had them that day whenever I've been there.
Express Adelaide?? u mean if they have to order it in the east like Adelaide?
No I mean that Unley Nissan here in Adelaide has always had diff shims in stock when me or a friend has purchased them, hence call them up, pay over the phone and get them to send them to you via an express post satchel so they arrive the next day.
Faster than 2 weeks from Japan and probably cheaper.
Black_CSR, which Nissan did you try?
I always go through Steve at Northside Nissan and I'm pretty sure Grifforelli got some from there last week.
I rang Total Nissan Cannington... Might call Northside then n try my luck.
Does any one have any negative on going to a ~4.6 shim, as in putting 2x 1.49 and leaving the standard .8's in there.?
Depends how worn the viscous unit is (if the shims have scored into it), a 1.49 each side was enough to lock my diff totally for a couple of weeks.
Bubba, has it ever single pegged since shimmed? Also does it still chirp around tight corners?
    • Holy smokes brother. If you get there before me, let me know if that was manageable with a hone. I still haven't done anything with mine and probably won't until I get the car MOT'd later this year so that I have another 2 years to do what ever needs to be done. I am at 86.5 now so at least I have the 0.5mm to go up from where I am, but that means new pistons at the very least. Honestly, might consider a stroker at that point.  Cheers
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
