I am running N1 Group A's at the moment. There is plenty left in them. Going a big single is a very expensive procedure and I like the throttle respose from the twins. The NOS kit cost me $650, 6 port direct feed. You do know its a 26 dont you?
  yokotas13 said:
if you need nitrous to get 650HP, you need to build your motor a little better
A real good friend just dynoed his r32 at 600HP. with no nitrous and N1 turbos
WALLY [aussie nickname for expert in thier field]
600hp on n1 turbos i doubt it very very much mate, best ive ever seen from n1 style turbos (2860r's) is 550hp and that was maxed out and a freak engine. 500hp is the usual figures going around from what ive seen.
US dynos read about 15% or more higher than dyno dynamics dynos so yank figures are no where near comparable :)
mine isnt 650hp either is was 605rwhp on 22psi Ken
plenty more to come in the future :)
yeah, i do.
how much is it to fill a bottle down there?
plenty more to come in the future :thumbsup:
it was here in japan. not US
turbos maxed out, engine built with cams, only the bottom end not touched
plenty more to come in the future :D
Have to agree, searched everywhere to find one putting out 600hp atw, not making itself know to me as yet.
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 馃槀  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
