Hey everyone,
Have been reading through the forums for a while but just signed up not too long ago and have finally taken the plunge and purchased an R33 today in Sydney through a dealer. I am over the moon and can't wait to see what fun I will have with it.
Its a silver (manual) gts-t Series 2 with white slimline NSW registration and gold 18's so if you see me driving around or parked make sure you say g'day.
I've got a few questions im eager to ask about what and who you recommend for parts and labour and trying to pass the dreaded roadworthy. I'm keen to get on a cruise in the coming weeks and really get into it if anyone has anything lined up. Right now I think I might take on a few more shifts to cover the obscene insurance bill and unexpected costs. Can certainly say it's a step above the old commodore and a totally new experience.
Look forward to meeting you all.
https://www.sau.com.au/forums/topic/164326-new-skyline-owner-in-act/
Cheers everyone,
Shell, I went through Justcar insurance for a somewhat reasonable figure which almost halved NRMA's quote of 4700 a year. Suppose thats one of the downsides of being 18, although the clean driving record certainly helped. Would love to come to the cruise on Sunday but I have to work on the weekends to pay off the bills and hidden costs that are piling up on me, not to forget that it needs a service straight away for the warranty to not get voided :). I noticed a thread on the top about where to service it so i will give it a read and go from there.
That was a pretty classy joke Veilside_R33 I actually laughed a bit. Will post a few pictures in the members rides when I figure it all out.
I didnt think the NRMA insured imports??? maybe it's changed now they're more common.. i dont think they used to?
don't say that!! you'll just encourage him!!
welcome Towlie, the hidden costs are fun hey?
you got quoted 2350 for insurance at 18?!
i got quoted 3700 from justcar for my s13... boo urns
try shannons? they were cheaper than most, with good service too, also Vigil were cheap.
Without a Roadworthy....
Why didnt the dealer give you 1
I called around and Canberra Connect said an ACT roadworthy certificate was required in any case. RTA confirmed this along with some other queries I had. The only problem I think I may have is with the wheels they put on the car. They passed roadworthy and added more registration with the standard alloy's but we agreed the car would be sold with RAYS forged 18's which happen to be 255's so a guard roll may be required or a change to different wheels but I will have to look into that. I'm not sure but I suspect the pod will have to make way for an air box as well depending on where you go?!?
SKYLVIA - I actually ended up paying around the 2800 mark for full comprehensive but that may also be because the car is fitted with a top of the line alarm and immobiliser and I've had insurance on my name with the VN. That being said the excess is a little high for both theft and accident but that is something that comes with age and the insurance rating 4 they were happy to give me. I did have a hard time convincing NRMA about the car in person and that's only because the operator's boyfriend drove a skyline (and managed to write it off) but decided it wasn't worth it in any case as they'd make it even more difficult in the case of a claim.
I read through some threads and gave John at Trojan a call about a service yesterday and found him to be rather helpful. He told me they were booked out this week but if I called him on Monday he might find me a spot or to swing on by.
Well now I'm stuck at work while you guys are probably out on that cruise so I'm gonna make myself look busy and earn some money to cover the car. Cheers for the welcomes. Will post pics shortly.
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
