ok guys my project 32GTR has come to its end nearly!
look out for it cruising the streets of sydney, number plates - - - URWSHN - - -
mods are as follows:
stock block - hot tnaked
new 33gtr crank
cp forgies 20thou over
stock rods, forged, linished, balanced
acl balck face bearings
arp rod bolts
oil stoned deck
new genuine nissan head gasket
n1 water pump
n1 oil pump
oil restrictor in head
head cleaned slightly
stock cams for now, will get poncams when motor is run in
cleaned up stock plenum
100mm cooler
044 in tank pump
sard reg
sard 720cc injectors
splitfires
iridium plugs - gapped to .7mm
power fc
adjustable cam gears
twin garrett 2860r-5
z32 air flow meters
oil cooler
stock b.o.v's
tomei baffled sump
car has previously run 11.70 with veyr little mods.
looking at running 22-25psi on shoot-out mode with some avgas added to the fuel, up the octane!
im hoping for 400rwkw, but i think these turbos will be my downfall! see hwo we go!
so let me know what you think, or how you reckon the car will go, and similar power figures maybe some of you have had!
cheers to all that have taken the time to read about my project! and if you see it cruising around flash ya lights whatever!
hope to see some of the fellow sydneysiders out at wsid when i go for the 10sec pass, on cruises, track days and at shopping centre car parks! hahahha yeah right!
see ya later all.
thanks
Garth
330-350rwkw. Stock cams will be your downfall there and will limit you around that point.
After than, you wont get over 400rwkw on PULP. Probably 370-380rwkw, could be a bit more. Depends on how happy the dyno is really.
Dont use AVGas. Just use a properly designed fuel like Sunoco, C16, Elf Turbomax and the others that dont come to mind
If you do use decent fuel, you should be able to make 420-440rwkw with as much boost screwed in as you can
So thats my bets in. Pretty general, but its pretty much what everyone else is making, so you shouldnt be a lot different in that regard
And btw - drop your sig size, its waaay to big (check the forum guidelines for sizing) :pwned:
I've heard there is unleaded avgas out and about now if you can find it.... I was thinking of running it for the next tune...
I'm not too sure the stock bov's will handle much past 15psi and may leak. :cheers:
To quote someone famous:
Avgas is designed for aero engines that turn over at a low rpm setting at constant speeds for hours on end. Not for an RB26. Use the proper fuel as it will burn better & generate more horsepower.
What rev limit you using im worried about pushing mine any futher then 8500rpm with the N1 oil pump. i think with cams you can run 360-380rwkws you will not need more for the street, if you need more for the Drag track just add 50-100 shot of NOS. And invest in GTR gearboxs HAHAHA
As for current power 315rwkws at 20psi my guess
Stock GTR BOV's are good for over 600rwkw.
They are good for a measly 15psi with small twins :D
thanks for the imput!
i believe i have the right set-up (with the cams) to make 400rwkw, if not, go shopping and buy a big single and external, then hope to mkae 500rwkw! it just keeps going on and on...
endless $$$ hahaha. thats cars!
thanks for all the responses and i will let everyone knwo the results when i get them!
thanks Garth
why buy a gtr to boast about the RWkw? theres a reason theyre 4wd and a reason there are 4wd dyno, if u wanted a high rwkw car, then why a gtr? i reakon 336rwkw :D
Edited by dead32
Why are you guys having a go at him? Sounds like he's doing this to get a 10 second quarter mile, not to get 400rwkw.
I think you will get it, the 10 that is. Dunno why you wouldn't put cams in while building the engine though.
Its definatly not impossible to make 400rwkw on pump but it will cost you - proper head and chamber work
done by someone who knows there sh#t, def cams and possiblly valves only said valves cause
thats what it took for us to make 435rwkw (98) and made it on more than one DD dyno.
Ryan
thanks for everything guys, at the moment im not changine the cmas on the run in tune! just wanna drive it. and yes i wanna crack the 10second barrier in my GTR. as for the rwkw, just easier way to measure power i guess, against other cars, cause not many cars will be keeping up with it around a track or on the old pac! hahaha!
nah im sure there are other fast cars out there that will probably beat it, but thats fine.
as for racing on the streets, nah dont do that, my dad would kill me as he builds drag cars for a living! so to answer it no i dont race, but i give it a squirt here and there! nothing crazy!
sounds good about c16 i think, avgas was my question as i could get it readily from a good friend of mine, and i work in the aviation industry!
as for the power figures, i was guessing 380rwkw with cam and c16, but if it gets more beautiful! and if it doesnt run a 10 second 1/4mile time, ditch them turbos and put the big single on, just to run a 10! keep the twin set-up for track days etc!
thanks to all for comments and advice, appreciated highly!
but cams will be done before the big tune... only going to use the poncams anyways! so it aint that big of a job is it?
cheers guys i will try and post some pics up soon if i can get them to load without being to big!
thanks once again!
garth
  • 3 weeks later...
garth how u goin dude...
u will get high 10 second passes with the setup u got now..
it was my car before and i was passing the line at 119.9 mph... with shithouse launches due to not wanting to break the box.
this was with only a clutch, dash 5's, and boost, still retained stock ecu and fuel system and mount, and obviously an exhaust
119.9 mph is pretty close to a 11.0 pass, that was with 19 psi screwed in..., with afew more psi, you wont have a problem catching 10.80, i recon...
only if u can drive it like me...
lol
speak 2 u soon dude.
denis.
